Topic: turbo cars - Subaru's maybe? Question about air oil separator
So, for one of the white Focus Club cars, we have a small turbo on the zetec engine. On the previous engine, we had a bit of a blow by / oil in catch can issue. Thought new engine would alleviate the issue, but only to a small extent. We have tried several things to slow down velocity in PCV tubes, etc... but to no real avail. At Gingerman, we ran the boost as low as we could, 4 lbs, and it ran ok and kept the majority of oil in the pan thankfully but anyboos level above 5-6 produces too much oil into catch cans to be able to run 8-9 hours.
My question is for anyone running a turbo really, do you guys run a catch can or an actual air oil separator that drains back into oil pan? Look at what is available in terms of products - seems most things are made for Subaru but there are a few generic ones around.
Do any of the fellow turbo Lemons folks run into similar issues with oil in crank case vapor and having to return the oil back to pan? Do you run a slight vacuum onto the can maybe by hooking small tubing to turbo inlet or?
Dr Google is all over the place with information, just looking to see what some of the fellow Lemons turbo folks are dealing with before going too deep.
Any experience would be awesome
Thanks
Pat
