Topic: Kill switch question with a bmw
Hey Guys,
Getting to the final stretch of Lemons prep with our E90, and had a kill switch question that I couldn't find a good answer for with search. The BMW has three power cables running to the front of the car from the battery - 1) starter/alternator, 2) engine electronics, 3) car electronics. A 6 pole kill switch would help me switch off two of them, and I was wondering if just killing the ECU and starter/alternator would be acceptable or if I need to find an 8 pole kill switch from somewhere to also kill the car electronics? I suppose I could also tie the engine electronics and car electronics lines to a single ECU rated fused line as the car wont need much electronics power anymore.
edit: one important detail is that circuit #2 and #3 have fusible links at the battery, so in case of a crash and short those will die safely on their own, which maybe helps justify leaving #3 unswitched.
A quick diagram of how the power is run from the battery to the front:
I am hoping to use the standard 6 pole kill switch sold here:
https://store.24hoursoflemons.com/produ … 4864832666
Thanks for your thoughts!
Marko
PS. See you all at the ridge!!!
