Topic: Modifying our 626
We just got back from Road America for the second race of our totally stock '99 Mazda 626 in new 'Galactic Cat-astrophe' theme, and I've come to the conclusion that some choices need to be made.
Bit of backround:
Back in '18, I had watched every Lemons video released, and I wanted to participate. Found this 626 on Craiglist for the asking of $380, with a flat tire, a front brake caliper clamped shut on its disc, an interior that had all but burned to the ground from cigarette holes, and no plates thanks to the owner's recent life choices. $300 and a case of Fat Tire saw me owning the thing, a five pound sledge, copious WD-40, and a bicycle pump saw it run well enough to get home. While getting money together for a roll cage, my 2000 XJ finally gave up the ghost, and for the rest of the Minnesota winter, I was driving a FWD manual with 212k miles on it that I had bought not sure if it would make it home, let alone actually be useful. It ran perfectly all winter.
In the meanwhile, got married and finally get up enough scratch to think about actually racing the thing, which we did in Brainard in '19. Aside from the removed interior, everything down to the replacement rims were OEM or the similar O'reilly Auto Parts product. It ran beautifully, actually making a decent showing in Class B considering we had no clue how to drive, and while we'd put in plenty of work making it race safe, we hadn't done a single thing to make it race ready. Cornering was very weak, braking was middling but manageable, power was fair, bordering on respectable in good conditions, and we had a very fun race. There would be back and forth as we got to the corners but all in all it was going to come down to just staying out there and cranking out laps.
Pandemic, Middle Middle Middle, jump start, get fire bottle checked, on to Road America '23! Things were going really nicely until about 3/4 through the first race lap, when the brakes suddenly gave a far less than noteworthy effort. Backing off to pace car pace for a lap saw the brakes return, but from that point on we were limited to around ~30-40% braking power, albeit keeping one or two good full power stops available. This was my 20 min evaluation that the thing could run at all, and after time was up I handed it off to my two other drivers.
They reported the same behavior for their hour long shifts, and then I Was up again, using the same braking limits. I had just started to get a rythm when, instead of just petering out, the brakes suddenly became something of a mild suggestion of the possibility of considering perhaps reducing the vehicle 's rate of travel at some unspecified point in the distant future. A good runoff area and having to already start braking at the (imaginary) 600 board kept the car out of the wall, but I was E-braking back to the pit.
In Brainard, one set of pads was used all weekend and had more than 50% left. I felt I'd check the pads after the first day, and I had one set of replacement pads just in case. As I'm sure many of you figured out already, they pads had been utterly dusted. OK, throw in the second set, I'll buy more tonight. We got two more hours out of 'em, and a trip to Milwaukee to buy the only two pad sets (and a set of rotors) within 200 miles saw us ready-ish for Sunday. We took the checkered flag, but only by sitting for three hours in the middle of the day.
Storytime over, now the real question. I've been extremely pleased with myself for keeping this thing, right down to the numbers-matching OEM steel rims I search for in a junkyard and working factory-installed climate control, utterly stock. The problem is, it was ruining the race enjoyment....we'd pass anything slow on the straight, then get re-passed as soon as there was a turn. This would happen for half a dozen turns, constantly watching for more cars piling on behind, before the pass stuck. Or whoever we were passing got bored of the repassing. us. It was an annoying, flow-breaking experience that was just ruining fun. I don't want to win, but having to set up every cornering moment so that half a dozen cars can get past you only to catch back up to them is just tedious.
Ultimately I would like some modest improvement in braking, and perhaps carry a little bit more speed through the corners. I could get some sort of performance brakes (ew) but I hear the much more capable brakes of an '03 Mazda 6 will bolt right on, albeit if I get 16 inch rims, which seems the lemons-y thing to do. The steelies have to go (they were so hot when we changed pads they could not be handled), so I'd like to find some brand X wheels that provide good enough ventilation, and at the same time hopefully be a bit easier to find tires for. I have no problem having to change out pads as consumables, but I'd love if I could do no more than one swap per day.
So the actual question: Are there some particular make/model rims that are very lemons-friendly, and easy to get proper sized tires for? I'd like to keep the outer diameter as close as possible to the original (205/60R15) but as mentioned. I need to move up to at least 16" to fit the newer front brakes. Since this will almost certainly be an at least slightly wider tire, are there any good ways to check clearances before ordering, short of making an actual mock-up? I'd like to use some of the Lemons-friendly Yokohamas (gotta feed the sponsors), but ultimately would be happy with just about anything that fits and isn't unobtanium to get replacements for. Any other words of wisdom/drunken rants also welcome!
The car, in current form:
1999 Mazda 626 LX V6
