Topic: Forum is doing that login redirect thing again...
Noticing that when you login, the forum is again redirecting you to a random post.
This is leading to people bumping 10 year old potluck posts and other disconnected replies.
@therood, thought this got fixed at some point??
Re: Forum is doing that login redirect thing again...
Put me down for a bowl of potato salad in NJ
I've got a crock pot of chili for Nelson Ledges!
That guy
Sounds like time to rebuild the index again. Let me see what I can do.
It took a few hours to run but the index rebuild completed.
Let me know if anyone sees weird posts popping up that shouldn't be.
I somehow lost the Hydrogen setting; after logging in it reset, so I'm good.
Logged out and the new format showed up again; logged in again and I'm back to Hydrogen.
Damn, that's annoying...
Still not 100%.
Now seeing the same behavior as Lemon_Newton-Metre describes. Logged out see the new theme. Login and see the hydrogen theme but also still loads a random post.
B.L.U.F.:
I try to remember to compose in a text editor before posting, though I don't always.
I learned about the random post redirect here early. I was surprised but trained by a different site - an auction site.
My training there came with emotional panic, as I apparently bid a LOT on an item different from what I had intended - and I didn't notice until too late to cancel the bid.
Thankfully, someone else bid higher than me.
I _really_ didn't need the "Leopard-print Cat Suit (S) with a tear-away 'nether part' (edited), gloves, ears, tail, laser pointer, feather wand, and collar.
(... I'm a M)
