Eeeeehhhhh, ok, yes, a can of worms may have been opened; but you're potentially resolving several problems that _may_ have taken you off track:
1. unable to restart due to a loose, dodgy lock cylinder, and
2. steering column lock pieces have been removed, so you're not going to hit the wall because you can't turn the steering column. (There may be other reasons you hit the wall, like blowing a tire, running out of talent, etc., but not because those little pieces fell apart and jammed up the steering column.)
That's why I think it's a great suggestion, regardless whether it's in the rules or not.
One of my candidate is a "city" car, with over 270k miles, not an over-the-road highway beast, with hundred+ miles each day. Probably 4 miles each trip, maybe. Think of the number of start cycles before I bought it, by however many drivers.
You'd change filters, and the oil, right? Brake fluid, pads? That stuff makes it run and stop.
How about making sure it'll start, and:
*** that you can turn corners whenever you absolutely need to while at speed***?
(Yeah, ok, barring a mechanical failure, which is a risk we all accept by getting on track)
That's why I think it's a GREAT suggestion, rule or not. And, your already resolving anything else you uncovered by taking it apart. That's a Win - Win - Win for me.
