Topic: selling a great beginner car 2002 VW golf VR6 24v
https://www.facebook.com/marketplace/it … 098287063/
****UPDATE car had a miss when a buyer came to look at it. suspected a vacuum leak or a clogged injector. Replaced both the gaskets and serviced the injectors. and now the car is running great again!
This is a 2002 VW golf setup to run 24 hours of Lemons. We just ran Road Atlanta in December see the wrap up vid. The car ran great all weekend. We won the Kim scrodium 500 trophy. this car was featured in the 2021 BFE Lemons wrap-up video andwas featured again in the 2023 Road Atlanta Lemons recap
This is an amazing beginner car. very easy to drive and very forgiving.
This is engine swapped to the BDF 24v vr6 which came in the 2002 golf gti so makes getting parts easier.
have an extra junkyard head/
6 speed manual
very clean car no major body damage or rust.
Have title
new front shocks and springs
new rear shocks
new motor mounts
new axles
new plugs, coil packs
new O'2s with a test pipe
new MAF
upgraded to aluminum radiator duel core with 2 electronic fans.
no body rust. block and some rust as the donor motor came from Virgina but the car is from CA/AZ area
professional built rollcage
fire bottle recert in october 23
belts are good till dec 27(bought december 23)
brakes and rotors look good for another race and have a extra set of stock style rotors new in box and front brakes new in box
tires looks good for another race but id plan on some spares
have the stock steel rims/spare for the car but the tires are old and will ned to be replaced.
upgraded from wheel bolts to studs.
has a button box installed with a horn button,windshield wipers,aux cigarette lighters.
NRG removable wheel
has a radio system that can be included. baofang system. good for a mile of range ish. push to talk installed on the wheel.
has a scoop mounted on the roof that is used to force air for a defroster/driver comfort.
big guy friendly wide seat and angled driver roll bar to make it easy for us tall and big guys to get in and out of
The bad.
It's a VW
paint job looks great from 20 ft away but not 5 ft away.
car leaks water from the plastic connecter to the radiator. we just use permetex to seal it and its good for a race weekend. if i was keeping the car id find a shop and extend the radiator lip and get rid of the plastic connector.
sometimes it likes to go into limp mode while driving on a long straight cycle the key reset it. (may have been injector related and many now be solved)
