1 (edited by Lemon_Newton-Metre 2024-03-22 11:19 AM)
Topic: *My custom tool* for my '90 Miata; timing belt / water pump and...?
[Edit: pics of the holding tool I made in a new post 03/22]
A leak started under the water pump / thermostat area, right in the center front. So I got the water pump / timing belt kit, and I'm finally getting to it after two years daily driving it - never revving over 5k rpm, though.
WHILE I'm in there, any suggestions as to _other_ favorite routine maintenance jobs that might get missed with a limited kit like that?
I bqusted the two bolt heads off of the bolts holding the thermostat housing together; that delayed me completing this. My tools are not organized, so I wound up buying more tools I already had, but couldn't find. Temp sensor was corroded, and broke with almost no effort when I removed the connector; there's a lot of corrosion in that area.
When I took off the top timing belt cover the belt looks new. No wear I can see, either on the ribs or the edges of the belt, and no cracks. But I have no idea how old it is, either; so I'm replacing it.
More background:
I'm second owner, manual, A/C (needs recharge, at least), no hard top, clear title. Probably sat for most of 5 years, with only about 500 miles over that time. Originally had 12 and 14 year old tires, so I've been babying it.
When sold to me, 3 miles more than previous year's inspection sticker showed, and had just had an oil change - totally clean oil on the stick. So I think the previous owner took care of it.
Rusty rockers behind the door on both sides, and door bottoms, and there are repair attempts that show; this isn't a concourse Miata.
Upper radiator house still has a label on it. The other hoses look in decent condition; no leaks I can see other than the one I mentioned, and no cracks. Screw-type house clamps on the upper _and_ lower radiator hoses. The smaller hoses have what look like original spring clamps on them.
Oil mist residue under the hood; looks like it's coming from the plug thingy on the valve cover (EGR?). Generally clean in the engine compartment otherwise; never any oil drips where I've parked it.
Adding a cup of coolant a month for so long eventually turned into a pint (an hour / 40 mi.), which was manageable; until the one day the coolant (what was by then just distilled water) just constantly dribbled out as it sat, until it was more than a gallon low. That's when I parked it.
Re: *My custom tool* for my '90 Miata; timing belt / water pump and...?
In case you didn't already know:  look up crank pulley issue on that year.  I forget the details but I think you need to loctite the keyway or something when reassembling.  I think there nay be a TSB.
(Oh, crap!) THANK YOU!!! I DIDN'T know about that. And I'm _SO_ glad I asked.
I was anticipating something like 'grab this little $20 connector, make / buy this bracket, get this $4 tube of something, and move this over here; it'll be easier, more reliable, and save you money' (which was actually a thing - different vehicle). Not something as important as you mentioned.
Time to pick a Miata forum, and go further down the rabbit hole (I'll start with the newcomer section).
I already have a lot to look at when the rain stops, to see what has already been done, if anything. And probably a few more things to buy.
Conveniently: it's nighttime now; and, it's raining.
Thanks again!
Get one of these, it makes it so much easier to keep timing: https://flyinmiata.com/products/flyin-m … generation
The car will probably need plugs and wires, the wires are a regular wear item.  Stick with NGKs for both.
Chris from 3 Pedal Mafia
If I still have it 60k mi. from now, that looks like a good purchase.
Sounds like NGK juice for Miata is like:
OEM ignition coil for Honda Civic.
That's more like what I was expecting.
I'll be looking at the woodruff key area closely; serial number is below 108,xxx.
6 (edited by Lemon_Newton-Metre 2024-03-13 08:49 AM)
Should I replace the camshaft seals, or is this a reasonable and expected amount of grunge after 157k?
https://i.postimg.cc/ZKcgDfQL/20240312-180649.jpg
https://i.postimg.cc/rsGbTgwM/20240312-181514.jpg
https://i.postimg.cc/c4ByG1vw/20240312-181518.jpg
https://i.postimg.cc/Jz7wrwXg/20240312-181527.jpg
Finished drilling open the thermostat housing: https://i.postimg.cc/50BpQydm/20240312-174943.jpg
Gonna charge the A/C system this year and see if this works:
https://i.postimg.cc/SxPgwHfc/20240312-174951.jpg
Some of the debris from the thermostat bolts (that'll be gone before putting together again) :https://i.postimg.cc/TYC7cKy7/20240312-175021.jpg
This belt needs to be replaced: https://i.postimg.cc/0j9nYv91/20240312-175126.jpg
https://i.postimg.cc/SxRZ1mCy/20240312-175151.jpg
This belt looks good: https://i.postimg.cc/BQq7DTvP/20240312-175301.jpg
But it's still finished here ;-)
New gasket for this(?):
https://i.postimg.cc/h483fyKq/20240312-175724.jpg
12 (edited by Lemon_Newton-Metre 2024-03-22 11:14 AM)
It doesn't look too bad, for sitting for probably 5 years. I've put - I think - 8k miles on it since purchase.
Any other suggestions? [snip]
13 (edited by Lemon_Newton-Metre 2024-03-22 11:40 AM)
Flying Miata is out of stock of their crankshaft holding tool:
https://flyinmiata.com/cdn/shop/files/35-61000_Crank_tool_092623--3.jpg
, so I made my own, which I think is an improvement on the original; but then again, I only have the one NA type:
https://i.postimg.cc/FHVDnxBt/20240322-072600.jpg
https://i.postimg.cc/8CywTzGt/20240322-072614.jpg
Found this pic on Facebook - that washer-and-bolt assembly is a great idea.
https://i.postimg.cc/xdjtrbwX/20240320-144259.jpg
14 (edited by Lemon_Newton-Metre 2024-03-25 08:00 PM)
I had a problem getting the crankshaft pulley off; I didn't think it would be something like 'sintered' aluminum, and as soft as it was. So, since I cracked the back lip of the pulley, can I just round it out (since I can't find one online - the dealer is next tomorrow morning)?
So, just how 'boned' am I (if I can't find another) [Partsgeek is the 4th site I looked at, and they had it - the 'crankshaft _gear_'] :
https://i.postimg.cc/jdjCbZM6/20240325-190640.jpg
https://i.postimg.cc/Kv9kkd1s/20240325-185220.jpg
Less importantly, I think I need new spark plugs:
https://i.postimg.cc/pdwKLbgw/20240325-144653.jpg
