Topic: yet another post requesting roll cage pre-approval :)
Hi folks.
I wanted to post some pics of our recently installed roll cage, it still needs the back bars to the strut towers installed, but besides that I had a few questions
1) besides the back bars, does it look legal?
2) I had to add a harness bar, but I'm worried I put it a touch too high, any comments?
3) Where should I add gussets?  I'm assuming right now just on the floor anchor points.  Anywhere besides that?
http://img37.imageshack.us/img37/7237/imag0115n.jpg
http://img37.imageshack.us/img37/9461/imag0112p.jpg
http://img37.imageshack.us/img37/6586/imag0114x.jpg
http://img37.imageshack.us/img37/2869/imag0113t.jpg
Re: yet another post requesting roll cage pre-approval :)
looks nice, but the diag should be one piece eh?
You'll kick yourself later if you don't hollow out that door and redo the driver's door bars for more elbow room.  I'd also consider lowering the upper door bar to make it easier to get in and out.
There could possibly be an issue with the diagonal not starting from all the way up in the top corner... but, don't quote me on that.
That's all I see.
I'm pretty sure his diagonal IS one piece.  It's the harness bar that's not, and that's perfectly okay.
Diagonal brace looks good as long as it is within six inches from the center of your vertical bend. You don't want it any further away since it keeps the cage from collapsing on the drivers head. Loren is "spot on" the door bars, the top one is pretty high which will cause issues when getting in and out, and too close to the driver can be an issue since your top bar will need padding as per rules. I love convertible cages they are easier to build you can give yourself as much headroom as you want. If your harness bar comes out center of the belt holes you should be O.K. the belts should sit at 0' to 15' degrees on the drivers shoulders which it looks like yours will.
Good luck with your build it looks good.
That's all I see.
Thanks for the feedback
The door is on the list smile... it actually doesn't close until we hollow it out.
The door bars seem pretty comfortable for elbow room, but you're right, it's a pain to get in and out of.  I don't think I have time to change them now though, maybe for rev 2
the back diagonal is one piece, the cross bars aren't, but they essentially are.  the harness bar is roll bar tubing welded on little stub-ups... due to clearance I had no other option.  I'd expect my harness hardware to fail before that bar breaks.
Oh ya, looks like I didn't see it right... Looks good overall. Generally the "NASCAR" bars have a couple verticals in them to prevent the tubes spreading....
Bender/StickFigureRacing wrote:
Diagonal brace looks good as long as it is within six inches from the center of your vertical bend. You don't want it any further away since it keeps the cage from collapsing on the drivers head.....
hummm... it might be close on that number, but as far as strength goes it should be ok since it forms a "hoop" over the drivers head.  Maybe I'll add a gusset to the inner corner for extra strength.
good idea, maybe we should add a vertical mid-way down the bar, far enough from the elbows.
Gussets are your friend.:D
Looks good !
Door bar I would cut door out and and run vertical tubes and tie into your door sill for extra protection . Expectional with 4000 lb cars out there .
