Topic: Engine Swap Question
I pulled this quote from a different thread, discussing the theoretical aft-ward engine relocation in a pickup.
You should use two {yokes} with a short driveshaft....the centreline of the trans output shaft and the diff yoke should be offset but parallel. If you can use a CV joint do it..the trans output yoke will vibrate less...
Help me understand more about the centerline of the output shaft and diff yoke needing to be parallel but offset. For what reason should it be offset?
-Dave
Scuderia Ignorante // Modena / Dearborn / Aichi Prefecture / West Texas
