So how much hp are you putting to the wheels with an SR20DET? How little traction do you have? Even with 225/50/14 R compounds and a locker rear end, my U20 roasts the tires at will out of every corner in 2nd and out of some in 3rd (such as 2,7, and 11 at Sears Point) and thats still is street tune. If you have some secret to getting the back end to stick please let me know. Right now, I have a really good drift car. It really fun to drive, but not real fast around an autoX course (too much time sideways, not enough time going forward. Always a crowd pleaser however )
I hate to say it, but few things make me more sick than seeing modern engines in a Roadster. There is absolutely no point or reason. Its not cheaper, its not more reliable, it just screws up another car. Heck, if I had the $, I'd buy someones nice looking swapper mobile and strip the thing for all its worth, use the body on my track car and the frame for a Lemons car since odds are its hacked up (especially with a SR20 in it.) On top of that the electrical wiring to make the engine work is too much b.s. I like simple stupid, easy to work on and fast.
As for using a rotary, only if its a 4 rotor. A 12A or 13b just sounds like crap. I don't care if it will turn 10K, I don't want to hear it.
I'd rather keep carbs on the thing since fuel infection (no thats not a typo) is a giant hassle. (Back to the electrical that shouldn't be there.)
KAs and Miata engines can be done so they don't require cutting up the frame, L series or NAPS Z engines sit too tall and have to be set way over on their sides (and make less power then a U20 to start with.) Not a big fan of the KA for really any reason, I'd rather do a ghetto charged Miata engine (lighter, fits better.)
Now, an Alfa 2L with a Miata head grafted on with a set of carbs could be really different. (And wrong in so many ways.) The Miata head will slip about half way down the head studs on an Alfa engine, the trick is converting the Miata head to use timing chains, and getting the coolant passages to line up. Just to top the madness off, ghetto charge it. What could possibly go wrong with that mess?
As for being small and so called slow, I've caught Lambos, 500 hp Mustangs and other assorted fast stuff on the track. Unless you are out to play bumper cars (and the looks of your car whether it be covered in dents, or with cones, chickens, or rabbits welded to the top of it will tell me to steer clear of you because you can't drive) there won't be an issue.
Will
Filthy Faux Porsche 935
1959 Alfa Giuletta 101.02 Sprint (huge project) 1969 Alfa 105.51 GTV (daily driver, now dead)
1969 Datsun 2000 (race car, current daily driver)
