Our problem was the stock fb driveshaft was too short, and the FC driveshaft was also too short.
We decided to use muffler tubing (what could go wrong?!) and It held up absolutely fine for 2 events, one rear wheel adapter/drum-disc converter failure -> hitting water barrels -> going 4-5' in the air over water barrels -> a whole lotta drifting.
We've honestly kept the car at $40x including brakes, but sans cage/fuel system, but would like to possible get a steel shaft made by someone who knows what they are doing. We're okay with super-ghettoing everything else (as everyone knows) but objects rotating at high speeds that can puncture floorboards/racetracks are a little sketchy...
The only reason it smokes the tires drifting is because I was playing no lift challenge and trying to come into the corner past full lock and dig myself out of the corner using the rear grip and raping the clutch to keep the wheelspeed up. Its pretty quick because it weights 1800# but the motor is stock with our $20 header and a used 3'' filter duck taped to the end of the stock intake. My friend replaced his AIR RAID filter with a K&N, and then I took it out of the trash after he told me he threw it away , lol.
can i petition for a clause that big heavy STEEL non performance increasing driveshafts may be used on bastardized cars where the distance is too great between yoke and imput flange to cut up the stock units?
Mike Peters
Former rotary brat pioneer.
3.17.08 Jalopnik Hoon of the day. #hasbeen
1984 Dodge Rampage, A few SHO engines, a Mustang 8.8, and a lot of hot glue going on now.
