Topic: Cage input
The 24 Hours of Lemons Forums → Lemons Tech → Cage input
Good welds, decent design. The powers that be are still allowing the diagnal to be divided so you are OK there.
Isn't there a maximum separation of the horizontal door bars? Otherwise it looks good IMNEO
main hoop plates look a bit small, what is the size of that plate?
Main hoop plates look to be ~6x6. NASA minimum plate is 3x3 and SCCA is only 2x2.
They are definitely bigger than 3x3
