A bad head gasket after 187K mi and 47 1/2 hours of racing. That surprises you?? Its somewhat surprising it lasted through nearly 2 races.
Maybe head gaskets for Subie 2.2l engines are like oil for some cars,. They should always be changed after every race?
I did a bit of searching around on the web and found this thread, which seems applicable. Sounds like you should be running a composite gasket, not the metal/Teflon later Subaru gasket,
http://www.rs25.com/forums/f190/t100250 … ained.html
Or maybe you should spend some big dollars or time and get/make one of these. The V12 Jag guys should probably go down this path too. Get some sheet copper and start cutting. Then anneal it and apply some thin sealant to each side.
http://www.summitracing.com/parts/SCE-S92494
Make: Get some sheet copper and start cutting. Then anneal it and apply some thin sealant to each side. Lots of drag racers use copper HGs.
Dudes Ex Machina:
https://www.facebook.com/dudesexmachina?Everyone who has ever built anywhere a 'new heaven' first found the power thereto in his own hell- Frederick Nietzsche
