Ok, before anybody else comes on here and flames you, make sure to use the search tool for "kill switch" and/or "battery disconnect switch". This is well-covered territory on this forum.
The short version is that you need to kill 2 circuits: the circuit to the battery and the ignition circuit. If that switch does not kill the motor at tech, you will fail tech. I'm sure you're aware of this otherwise you wouldn't be bringing it up here, right?
Are you using a 2-pole or a 4-pole switch? If you are using a 4-pole switch then you can connect the large lugs through the positive circuit on the battery and the small lugs through the ignition circuit. By which I mean take the wire that is hot when the key is in the "on" position, run it to one of the small lugs, then run the other side of that wire from the other small lug. Your wiring harness and keyswitch may be different, so YMMV and read your wiring diagram. Turning the ignition switch to "off" thus closes both the battery circuit and the ignition circuit, which closes the main relay and shuts off the alternator and thus the motor.
Personally, I like the Longacre kill switch, although others have indicated that they've had one fail, but I haven't. Longacre part no. 45788 is a 4-pole switch and is weatherproof to boot. It's also about $10 more expensive than part no. 45785, which is identical except for the waterproof part, but that $10 will seem mighty well spent when you get caught out in the rain, especially if your kill switch is exposed to the weather.
Good luck!
