From BMWCCA club racing rules:
Each team that refuels must have a fireman with a fire extinguisher with a minimum nominal capacity of 10 pounds and a minimum UL rating of 60B:C.
NASA enduro rules:
All competitors are required to keep two gallons of water, at least one 5 lb. or larger ABC rated fire extinguisher (with a gauge indicating fully charged), and at least 5 pounds of oil absorbent in their pit space.
If your refueling fire bottle meets or exceeds the BMWCCA rule above, you should be fine just about everywhere.
EDIT: Looks like a 10lb 60B:C is under $50 shipped.
http://www.google.com/products?hl=en&am … ;scoring=p
For what its worth, It took a Lemons race to realize that a 2.5lb bottle in the garage will be horribly undersized if something goes wrong while working on my car. I now have a 10lb dry chem bottle and a giant CO2 bottle at home. The CO2 bottle was an expired unit from a friend's business. They decided to replace all their CO2 units rather than recertify. The gauge is in the green so I think its fine for home use.
