Topic: Cage question (my turn to bug everyone)
Rear down bar. I wanted to tie into the shock tower or the frame, but that was not practical on this car. My plan is add gussets to tie to the rear frame section. Is this OK?
Main hoop and diag. brace. The box on the floor is made of 1x1x 1/8th square tube contoured to the shape of the floor and then the 1/8 spreader plate on top, you cannot see it but there is a 1x1 square tube that runs at a 45* under the spreader plate. The 1x1 tube is also welded to the rocker (behind the main hoop tube in this pic).
Front a pillar bar. The floor was a little weak in this area, so I patched it with some sheet metal from a 1/4 panel (same gauge as the orig. floor) then I put two over lapping spreader plates in.
Rear view of the cage. Here you can see the diag. bar and how it ties in with the halo bar and the rear down bar. (yes I know I need another rear down bar on the other side). My rear down bars are at 46.3* and this was a big part of why a put them where I did.
I just want to see what others have to say before I weld more. I still have the door bars (two on each side) and my harness bar, but those are easy and I don't have questions about them. Does anyone see any areas of concern here?
http://dumbshitswithabeater.blogspot.com/
