An oil cooler is a nice idea, but if your neon is overheating an oil cooler is not how to fix it. Last August at the Arse-sweat-a-palooza, we ran a single-cam neon with a stock cooling system, and it didn't overheat despite ambient temperatures above 95 degrees. How did we do it? Attention to detail. We ran the stock, original radiator (the A/C equipped unit, not the tiny non-A/C part) and stock single fan. We left the heater core and ventilation fan in the car in case the car ever got hot, but we never had to turn the vent fan on once. Yes, we ran the stock hood, bumper and headlights on the car.
What's the key detail? The air MUST go through the radiator. What non-stock part do you see in this picture?
Other than the 2.4L engine (added before last year's Arse-Freeze-a-palooza), you might notice that we removed the metal upper radiator mount brackets and replaced them with ordinary vinyl cove molding. That's the stuff that you see at the base of the wall in most commercial buildings. If you look around, you can probably find some leftover stuff for free. We also used the same cove molding to close out the sides of the radiator so that the air was forced to go through the radiator. This was important because remoiving the A/C condenser creates a big air leak in the system. We left the stock headlights in the car because they look interesting, and they fill the holes in the core support so that - you guessed it - air can't easily bypass through the headlight openings in the core support.
OK, now what non-stock part do you see in this picture?
My clever teammate Dave replaced the little plastic stock airdam with a bigger part made of brownish fiber lawn edging from the hardware store. It bolts on the lower edge of the core support just like the stock part, but it is quite a bit lower than stock. It might help with downforce on the front end and/or reduce drag, but I like it because it forces air to travel up to the radiator.
OIL: Good oil like Mobil 1 4T Racing 10w40 sportbike oil probably won't care about elevated oil temps. It didn't on our car, which ran well and consistently enough to finish 8th overall in the 95 degree+ heat last August at Buttonwillow.
Plymouth Neon
