Richardnew wrote:Our Master Switch is Chumps legal. We're not sure about Lemons. It's on the right front upright of the cage.
Just two days ago, I discussed this with the Cal Club (SCCA) tech inspector who will be helping with Lemons tech at Buttonwillow in December. He said that the physical location doesn't matter as long as it is easy to see, easy to use by a rescue worker, and CLEARLY marked. It's your life at stake.
I also asked him to clarify where (electrically) it had to be. He said that it must disconnect ALL electrical power to the car, including the starter, engine computer, and everything else. There should be a single cable from the battery to the switch, with all other connections downstream from the switch. Additional switch poles may be needed to kill the output from the alternator.
He went on to say that the 50 amp switches commonly found are not sufficient, and that you should pay the extra bucks for a race-quality 200 amp switch. The cheap switches will not stand up to typical starter current.
All that said, it should be noted that he was speaking from the perspective of the SCCA rules, and that other groups may or may not allow deviations from it.
Just one personal note: My one pit crew experience was on a practice day at Willow Springs. My friend was driving a rented formula car and had come into the pit to check tire temperatures. Without warning, the fuel banjo connector broke and fuel started spraying all over the car and driver. Because the master switch was not obvious, we lost valuable seconds before we got it shut off. Fortunately everything ended well, but those few seconds delay could easily have resulted in a much less happy outcome.
