I hated my Spitfire engine, but you could easily fit two of them in that space.
Height is the killer (as learned from trying to find an engine to fit in the space of a Spitfire engine). If you can add a few inches to the height, the length and width are very easily attainable from a plethora of modern engines.
If you can fudge on the height, look at a Miata drivetrain.
