Topic: U-joint replacement needle rollers / caps
I bought some of these (EMPI brand) and I did what I thought was the right thing-- I pressed (read: "Knocked") out the bearings so that when I welded the ujoints to the shaft I wouldn't overheat and damage the bearings and cups.
Well, I guess I screwed up somehow because even before this thing has been on the road I have a bit of play in the bearings of the u-joints. I know this could be because of missing roller bearing, but they are all in there and in place-- I'm 99% sure of it. One did fall out of place and prevented me from pressing the cup back in fully, so I pulled the cup off a second time, refit the roller, and put it back on. Anyway, I think i distorted the "tin" cap/race while taking them off and putting them back on.
I really don't want to have to cut out and reweld entire new joints since I welded them the full radius (would be almost easier to start over from scratch).
Any suggestions on where I can simply get the "virgin" uninstalled replacement u joints?
Next time I'll just do what I did the first time-- tack and cool, tack and cool and maybe hold the bearings in water while I weld the shaft to the collar.
Appreciate any help offered.
