Topic: cage questions.....
Hope nobody minds I lifted their pictures for this question.......
which one of these is better?  In the bottom one if the vertical of the hoop was welded to the bottom plate and the side plate on the vertical would that be good?   Ive also seen some guys build boxes of the floor with plate and weld the vertical from the hoops to the top of the box.
i planned on going the second picture route and getting some weld on the vertical plate tied to the sill as well.
thanks
http://llracing.weebly.com/uploads/5/4/7/0/5470636/6589351_orig.jpg
http://i944.photobucket.com/albums/ad286/trekkor/E30%20track%20car%20build/P1110226.jpg
https://www.facebook.com/TeamDeathrace
This ain't a parade folks, it's a race.
Re: cage questions.....
Running the reinforcing plate up the sill is usually much better than keeping it only on the floor.
http://teamdfl.com/Lemons/diagonal4.jpg
http://www.teamdfl.com
The second picture is the better way of doing it.
Philly River Rats, 1989 Honda Prelude (covered in Fur)
Cuba Norte 2010 (PBIR) headgasket and spun bearing, Real Hoopies of NJ 2011 (NJMP Lighting) 2 motors, Halloween, Hooptiefest 2012 (NHMS) 24th overall, Halloween Hooptiefest 2013 (NHMS) 23rd overall, Real Hoopties of NJ 2014 (NJMP Thunderbolt) clutch and turbo 55th overall
Way better...         In interest of full disclosure, that's one of my cage kits installed by someone else....
So what's your unbias opinion though, pretending you didn't build the second one smile
And better yet....why?
Maximum Efforts Motorsports
Mid-Engine Chevette
S-10 incoming...
It ties into the strongest part of the car: the rocker panel.   You should always try to tie into the rocker either with a box structure or a vertical plate like that.    It also ties into the cross beam under the rear seat.
   The installation of this particular plate set is not ideal..     but you get the idea.
-John
