Topic: mounting items to the roll cage
For our battery cut-off switch I want to mount it to the dash bar to the left of the driver. That way it can be turned off by either the driver or a track worker. I've got a solid box, good switch and I have it mounted using some hoops but it's still spinning on the cage.
Is there an issue with drilling one small hole on one side and tapping it in order to just keep the cut-off switch from spinning? I suspect it's OK but I wanted to check and ask. Plus I've seen other people pass tech with bolts running straight through the dash bar, far more than what I'm looking to do.
