Topic: Bolt in rollcage, shoulder belt anchor points, floor insolation remov?
We have an autopower 6 pt bolt in cage. the side bars that connect the front and rear hoops are connected with bolted in tube sleeves, are these OK? The backing plates for the cage are about 6"x6" 1/4" thick, are these OK? The shoulder belts are anchored to the floor at a 45 degree angle 3 inches apart and staggerd, is this OK?, How much of the insolation must be removed from the car? Do all interior panels need to be removed? Can we keep the dash or does it have to be removed?
Too many questions too little time.
joe
