Using card stock to make a template, make a box out of 3/16 plate like trekkor says. You probably want something perpendicular to the sheet metal at the strut tower so the 3/16 plate isn't on edge to the thin sheet metal.
Square stock perpendicular to the towers would work if you were up against something flat but from here it doesn't look like it would work in this case.
Known Associate of 3pedal Mafia, Speedycop, and the Russians. Maybe even NSF.
