doctawife wrote:EyeMWing wrote:If you don't weld on the car with the ECU in, and you don't bake it in engine heat, there isn't much you can do to kill it.
As for homebrew engine management, megasquirt. It's not really doable on a lemony budget unless the rest of the car was free, but you can adapt ANYTHING with that system.
Not true! Be very very very careful while installing the kill switch - if you do it wrong (which we've done) it will kill your ECU. Once you get past that hurdle, then life is pretty much worry free.
Granted, we created ECU destruction before our first race when we were very green, but I'm just sayin' that it can happen.
Regarding your original three option question - go with #1, provided that you test your kill switch well in advance of a race. If your kill switch doesn't kill your ECU, you're golden. If your kill switch does kill your ECU, there are work arounds AND you'll have time to find a replacement.
So... for a more technical explanation of "don't f- up your kill switch install":
Don't open-circuit your alternator output when you open the kill switch, especially if the kill switch leaves it connected to the electronics. The alternator will spike to a buttload of volts and destroy whatever is connected to it.
Here's the skinny:
WRONG (Kills your alternator)
REALLY WRONG (Kills your ECU and pretty much everything else)
RIGHT
The correct wiring will allow the field from the alternator to discharge into the battery instead of into your ECU. You need a fusible link near the battery on the alternator line to protect the cabling in case of a short.
Back on the original topic, the ECU is the most reliable thing on your car. Don't worry about it.
Dave Heinig -
Schumacher Taxi ServicecoROLLa - 2 time loser, RWB MR2 - 5 time loser
