Topic: Help me fix my other car (long)
There are quite a few good wrenches here, so I figured I'd throw this out to hear some opinions. The car is an '85 Ford LTD LX with a '93 Mustang 5.0 swapped in. AFR aluminum heads, Cobra intake, has been running fine with this combo for several years until I discovered an external coolant leak at the back of the lower intake.
Two weekends ago I changed the intake gaskets on my car. I was expecting the gaskets to look warped/smashed, but they appeared fine. Swapped in some new steel core Felpro 1250S-3s (with thin film of RTV around coolant ports) and called it good.
I didn't have a chance to change the oil or retorque the intake bolts after letting the car warm up and cool down, so I waited until this past Saturday to do it. Topped off the coolant, and headed out for a drive. When I stopped I noticed I had a coolant leak. I forgot to tighten up the hose clamp on a heater tube hose (above the water pump). So I tightened up the clamp and headed home. Temp was fine the whole time. When I got home I noticed the overflow reservoir was overflowing. I waited until the car cooled down and opened the radiator cap and it was holding a bunch of air pressure. The air pressure gushed out (along with some coolant).
I chalked this up to being a lot of air in the system due to the coolant leaking out, so I jacked up the car so the front was in the air (to bleed the air out), topped off the coolant, and let it idle with the rad cap off. Temp got over 200 (which is odd, electric fan normally comes on around 190) and the coolant started geysering and gushing out of the radiator. I let it keep doing that and eventually it settled down and my fan came on. Car started running at normal temps and the coolant level stayed at the radiator neck. No bubbles at all in the coolant. Great. I called it good, put the radiator cap back on, and took the car for a spirited drive. Temp was fine (190), but I had the same problem, overflow reservoir was full, cap released a lot of pressure, and the level of the coolant was down.
I have since pressure tested the system and it's losing pressure. The only external leak I could detect was a small leak in the radiator core. I only found it by hearing a slight hissing with the garage door closed, but there seems to be no fluid leaking out. I can feel the t-stat open by the upper hose getting hot and firm. The issues I'm having are commonly caused by a bad head gasket or cracked heads, so I used a block tester with the car running and the fluid did not turn yellow. Based on that, and the fact that I could see no bubbles in the coolant, it doesn't seem likely to be a head gasket problem, but I have yet to pull the plugs or check compression. Just for fun, I drove the car normally (1/2 throttle or less) for a couple of hours while running errands, and the overflow tank filled up again.
Common sense would dictate that the only thing that has changed is the intake gaskets, so the issue must be related to this, but I can't figure out why. Any suggestions or recommendations on what else I can do to diagnose this without pulling the engine apart again?
