firehawk wrote:jrbe wrote:I agree on the easy lap before you come in, especially for brakes. A turbo will not cool of while you are driving it. I had an egt in a blocked off wastegate port (used an external wastegate) and the difference between driving really hard and normal wasnt much. Idling is the only way to let the turbo cool off. Thats not gonna happen on a racetrack. A trick is to have the turbo plumbed far away from the head, they run much cooler far away. Not always possible.
Sounds like something is wrong. A turbo will run MUCH cooler when it is not in boost, versus boost. Stay out of the boost on your cool down lap, and egt's will drop significantly.
Do you have any testing to prove this? Egt's dont care if you are in boost or not, If theres hot exhaust going by the turbo will get hot.
Heat becomes an issue in turbo cars in boost when the ignition timing gets low to avoid ping. This is from low octane gas, high compression, low ignition timing or combinations. When you get to the limits of the compression and octane and the timing starts getting down to around 20' and lower there is a ton of heat going in the turbo from the combustion event happening late. The heat/energy under better ignition timing instead gets used to push the pistons down.
The testing I did was with standalone, EGT in the turbine housing, and a wideband 02 sensor. There was about 16" between the turbo and exhaust valves. You could argue ignition timing was too low. I went from about 30' in light cruise up to 50' of timing (7.8:1 engine) through the light throttle maps. EGTs didnt move much. I build and tune turbo standalone cars for a living and have been tuning standalone for 15 years.
I would coast home for 2 minutes to cool the turbo down even though it was water cooled to get the temp below 700'F (lowest idle temp the turbo would go without running it rich.) When driving (light cruise, not trying to get around a track) the temp hovered around 1150'F. At full spool it would go to 1400'F.
The closer a turbo is to the valves the more heat that the turbo sees up to the current peak egt. If you put an EGT in a turbo on a subaru for example (long distance from the valve to the turbo) you will see very low temps, highest i remember seeing on the last one I did was 900'f at the turbine housing. If the EGT probe was at the egt peak temp point in the exhaust it would obviously show a much higher temp.
If you pop the hood on a 1.8t vw/audi you can see the turbo glow at idle. Yes, it will get hotter while driving as theres more energy/heat in the exhaust.
The hotter the oil the thinner, it will mostly drip off the turbo bits and down the drain. The thin layer left over that burns turns into carbon. When this carbon builds up and eventually blocks the drain in the turbo the oil has nowhere to go so it goes out the seals. The coking accumulates slowly. If its clean and the turbo drain is clear theres no way the turbo will coke up and cause a failure during a race unless there is an oil supply issue. Overspinning it, running it lean or rich, surging it, or overheating it with low timing can destroy it.
The oil supply line can get oil crud/sludge in it and end up blocking the turbo feed if a chunk gets dislodged. Cleaning the oil supply line is a really good idea.
The only problem with the op's oil cooler above the turbo is the oil supply line is usually small, so filling up the oil cooler (forcing the air to drain out the turbo) means the turbo oil supply will have a delay. This is no good for the dry turbo. This can do bad things to the bearings until the oil supply gets there. Its especially bad when the driver gets excited to race and spools up the dry turbo.
The highest rpm's i've seen on a turbo map were 250,000rpms.
BS inspectors will overlook an fittings for fuel and safety stuff. For an oil feed you could argue its for safety. Rubber hose will fail, possibly in a firey mess but a turbo didnt have to be added. Pretty sure they will count it towards the $500. If the engine came turbocharged and the line looked sketchy, bring pics they might let you get away with an fittings/hose.
Water cooled turbos can use convection after shutoff to help keep them cool. Better OE systems use an auxiliary water pump and can run the radiator fan like crazymike said. Water cooled turbos keep the bearing housing below the coolant boiling temp which depends on pressure but figure 260'F. Good synthetic oil will have no problem with this.
If the oil drain line, oil feed line, and center section are all clean i really doubt you will have an issue caused by coking. If it was ready to fail it could fail during the race. The g's could break a chunk of coking loose and block the drain or feed. Clean hot oil could start breaking down sludge/coking and cause an issue too.
