Topic: More Cage Advice
NEED TECH ADVICE!!!!
1984 rx7
Ran a string over the front and rear hoop centered over the drivers head and found that we did not have the 2" clearance. So we lowered the rear of the seat and bolted it to the floor which lowered the drivers helmet enough to be in compliance with the rule. Is this the correct method? I found this in the scca gcr and it is referred to as "helmet reference line" gcr 84.
We have an autopower bolt in roll cage and the base plates are NOT 24 sq. in. Can we add put 24 sq. in. plates under the cage plates with matching size plates under the floor and bolt through with grade 8 bolts? It's going to be fun shaping the top and bottom plates for the rear wheel wells. Can these plates be rectangular or do they need to be square?
Other possible issues/problems:
Is the bolt in cage is legal?
The bolts that hold the sleeves appear to be grade 5 is this legal?
Is it possible to get a Lemon's tech person to tech this car well ahead of the Gingerman event?
I DON'T want to be building the car to compliance at the event.
Any suggestions or help would be greatly appreciated.
joe
