Topic: Master Kill Electrical Switch
I'm trying to figure out how to wire the switch so that it will interrupt both the battery and the ignition as required:
Both the main battery circuit and the ignition circuit must be interrupted by the kill switch (if you don't do that, the engine may still run off the alternator even after the battery circuit is disconnected).
It seems to me that unless I use a double pole (?) switch, that the kill switch simply becomes my ignition switch.
Any insight would be greatly appreciated.
