Topic: Everybody Love Carnage.....
why don't we have a Lemons carnage thread... I mean with the relative ease that we break stuff someone should be keeping track of trashed parts.
Ill start!
Chinese bearing bomb!
http://im1.shutterfly.com/media/47b9d627b3127ccec798585d5bd600000010O00QbN2zhyycMge3nwM/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
http://im1.shutterfly.com/media/47b9d627b3127ccec79871d71bd000000010O00QbN2zhyycMge3nwM/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
http://im1.shutterfly.com/media/47b9d627b3127ccec7991e7e7b9a00000010O00QbN2zhyycMge3nwM/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
No Budget Racing
Chief Instigator
1991 Ponticrap OnFirebird
Racing a Camaro/Firebird at Lemons is a box full of fail, thats why we do it.
Re: Everybody Love Carnage.....
Impressive
Fall South 09- 23rd place
Brake pads?
http://inlinethumb19.webshots.com/46034/2714929180059037032S600x600Q85.jpg
4 (edited by cpmskinny 2009-08-07 09:17 AM)
Ill start!
http://im1.shutterfly.com/media/47b9d62 … /ry%3D400/
I have never seen something quite that bad.  WOW  Must have had way too much horsepower in that thing.
"Sharp as Bear Claws and Slicker Than Goose Shit"
Lab Rats Motorsports
1990 VW Jetta
Charlotte, NC
Though I don't have pictures yet, out transmission from T-hil 08 which had only 1.5 gears left has a cracked/raised case above the pinon section.
We lost all tranny fluid on that Saturday-- fixed the problem, but the damage was done.  I was able to drive ~ 10 laps on Sunday with only 2nd/5th gear--- then Fecond (first & second) showed up to play-- a different ratio unlike 1st or 2nd, a tag below 3rd ratio wise, but located in the area between 1st and 2nd-- thus Fecond.
It sounded like I was throwing silverwear, nuts/bolts into a garbaged disposal!
Thats just awesome haha
Team Magnum PI ness  #357  -
106th place at Nelson Ledges - The Lamest Days
-oil pressure failure leading to engine failure
Clutches? We don't need no stinkin' clutches!
http://img125.imageshack.us/img125/5521/clutchcarnage2bs7.jpg
http://img237.imageshack.us/img237/3411/clutchcarnage3gv6.jpg
Reno Damage for the Underground:
http://img199.imageshack.us/img199/4425/imagejpeg21.jpg
http://img199.imageshack.us/img199/4789/imagejpeg20.jpg
9 (edited by Voice Of Reason 2009-08-07 10:14 AM)
Ill start!
or a used ring and pinion put together with chinese bearings... all 170HP that the LO3 v8 pushes against a blown carrier bearing nets you what i have accomplished. i wish i had a picture of the axel that was friction welded into the carrier......
edit: twizzler connecting rod for the win
No Budget Racing
Chief Instigator
Ill start!
I believe that thing should be bronzed and sitting on the mantle, no matter what the wifey has to say about it.  That is quite a feat that you have accomplished.
1990 VW Jetta
Charlotte, NC
That's a nice clean break...
Love the piston rods... almost as good as my buddies ProStreet that ate it's self.
Sons of STIG
http://cache.gawker.com/assets/images/jalopnik/2008/12/BurningSciroccoBlockHole-Light804.jpg
That's a flashlight shining all the way through a Scirocco engine block at Thunderhill.
The No budget racing pinion gear should be made into the carnage trophy. That thing looks great and has a torch style to it.
pen
We sent the twisted rod to Lemons HQ so hopefully someone will be seeing it soon in a trophy lol
You want to see carnage? Wait until you see what happens to brake hardware at Buttonwillow! Hey, maybe Car-Freshner can make a That Burning Brake Smell air freshener!
I don't have any cool pics but I can make a list of stuff we've killed.
We seized our motor in practice two weeks before the second race due to incorrect bearing installation.  Working on the car late at night may lead to some boo boos.  We replaced the 1 sieved rod bearing, replaced the crank with one from a free motor I got and swapped the rod and piston.  We saved the motor for like $50-60.
Our most common issue we have had has been clutches!  Our first clutch died as the lining material left the disc in chunks.  It was off our parts car and came as no surprise when it died.  The second clutch on the other hand was unexpected and looked like cat hair in the pressure plate.  It died after the transmission got screwed.
We bent the roll pins on our 4 speed causing us to lose 4th gear in race #2.  In race #3 something happened to the 5 speed and it vibrates the car, don't know what happened yet just that the vibration is from the transmission.
Our battery hold down somehow grounded the battery.  This smoked the positive battery cable and caused the battery to melt around the hold down.  Miraculously, the battery and alternator lived through the whole thing.
We've had miscellaneous issues but nothing as cool as adding air cooling to a water cooled VW motor.
Troy, don't you know that you are supposed to reverse the battery orientation in a Z?  For some unknown reason, Nissan thought it was a good idea to position the positive battery terminal on the outboard side in very close proximity to the fender.  The negative terminal, on the other hand, is in wide open space where it can't touch anything.
Simply find a battery with the poles reversed and wire the leads so they reach.  Most Z cars have chunks of the fender support missing where the battery has tried to weld itself to the car.
'74 260Z
Our first Lemons (or race, for that matter) is just a few days away so haven't had any breakdowns quite yet, but plenty of carnage while building:
Right thumb (lost part of nail early on and as it was growing out, hit the end with a 4-1/2" cutoff wheel right down the top of the digit!
http://hubgarage.s3.amazonaws.com/photos/1440757/100_2263b_detail.jpg
Left thumb: this is a grinder slip while hand-notching some roll cage tubing.
http://i89.photobucket.com/albums/k213/Spank226/Lemons/100_2345.jpg
Well, I guess we have s-o-m-e carnage, but it's the piston that was in the motor we're using (and went back in!)
http://i89.photobucket.com/albums/k213/Spank226/Lemons/100_2349.jpg
--Spank
Spank, when you button up the bottom end, DO NOT re-use the tin rod-bolt locking tabs....either get new ones or Loctite them....and check the crank oil galleries...I've seen some A-Series where they barely line up at both rods and mains. I used to chamfer the holes slightly with a Dremel tool.....good luck out there...it would be great to see a Mini go the distance
well since we are sharing boo boo pictures... i got one of those as well.
angle grinder w/no guard + hood scoop plunge cut + unseen hood support bracket=
http://im1.shutterfly.com/media/47b9d631b3127ccec781de02a11b00000040O00QbN2zhyycMge3nwM/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/
ITS ONLY A FLESH WOUND! crazy glue and butter flys prevent an emergency room visit for stitches.
No Budget Racing
Chief Instigator
