tshand wrote:We are one week out and our car is still not running. We have fuel up to the fuel distributor but a) don't know how to tell if the fuel distributor is working and b) what to do if its not as it isn't like AutoZone carries them.
We have the fuel system fixed-ish. We have the fuel pumps direct wired and will pumping fuel. When we try the engine, it turns over for a second or two then stops.
Other thoughts on what might be not working?
Your calendar? Unless you're running in a different series, or planning on a long tow, The Ridge was a couple of weeks ago.
Not sure what you mean by fuel distributor. Injection pump? One thing you can do is try cracking a fuel line where it goes into an injector, just a little bit, and see if fuel comes out.
Have you measured your fuel pressure?
Are you sure it's a fuel problem? In my experience, 90% of fuel problems are electric.
Start with the basics, make sure you're getting fuel and spark. Figure out which one you're not getting, then work your way backwards from there.
bs
