Re: Working AC?
rmcdaniels wrote:While we're on the subject of race car AC, has anyone ever built a refrigerant-based cool shirt cooling system?
Not in the car, but yes. I built one from a window AC to use in the pits at hot races. fantastic for when you climb out of the car overheated and feeling gross. Supports 3 people as pictured. I have the parts to add 2 more loops. Cheap temp controller keeps everything right within +/-2 degrees of set point. Add antifreeze if you want to set below 34F or so.
Is that an Inkbird I see...if so, you must be a brewery.
