Topic: harness anchor bolts
rule excerpt:
3.F.2.b Harness Mounting Hardware. Grade 8 or better hardware and 2.5-inch or larger load washers are required when mounting to sheet metal.
I couldn't find anywhere advertising a grade 8 eye bolt of the typical size for a harness snap and my FIA harness came with bolts stamped "8.8" (a metric grade about equal to grade 5). So I ordered the pyrotect eye bolt with washer kit in the Lemons store (can't post links yet but easy to find)
These are also stamped with "8.8" (they look the same as what came with my harness). The nut has no grade tick on it, so I will probably throw that away. The washer is the correct 2.5" diameter.
Is the Lemons store kit legal? If not, where should I get a grade 8 version of this?
