1 (edited by craznoe 2009-12-27 01:11 PM)
Topic: Camera mounts - vibration reduction
My Canon that I use has optical image stabilization, but it's not enough to take care the shakes and rattles that our little 4 banger dishes out.
All you guys with butter smooth vids, how do you keep the camera shake out?  Is it post-production?
Right now I'm just using a Ram mount on the cage. (rookie)
Then again, maybe it's a good thing you can't tell what we're doing...
The Cannonball Bandits | Facebook Fan Page | Unununium Medal Winners 2010
3X Organizer's Choice Winner 2010 - Sears Pointless, Goin' For Broken, Arse Sweat-A-Palooza
1X Organizer's Choice Winner 2011 - Arse Sweat-A-Palooza
Re: Camera mounts - vibration reduction
I use an IO port camera mount attached to the roll cage...it works pretty well....heres a link to some of my videos and a link to the mount
http://www.ioportracing.com/Merchant2/m … ry_Code=CM
http://www.youtube.com/watch?v=TBi3fuHUEmo
I use an old sony digital camera that records in 640x480 for all my videos
Richard Doty
1984 Porsche 928 "Estate"
Dirt Poorsche Racing #2
The one time I mounted my HD camcorder in the Mark VIII I used a big chunk of neoprene pipe insulation as a vibration damper. Worked OK, but something even softer would probably be better.
I've got the same mount, with an old JVC digital camera wink
Same here.
http://www.youtube.com/user/kt746
KT
We use this...
  http://i134.photobucket.com/albums/q102/travisgt45photos/joe/P1010649.jpg
to get this....
http://www.youtube.com/watch?v=dJNnic5vM5g
Not too bad for a hunk of bent metal and a tripod doo-hickey.
We are the people your parents warned you about.
Here's an example of ours: http://www.youtube.com/user/craznoe#p/u/3/L9G5lu9H4So
The mount felt solid, but I'm unsure what's a better goal - Good material insulating vibrations (like that fancy mount posted above) or direct, solid mounting to the cage (ala the TAJ Racing mount).
It seems that my mount just sucks. smile
The trick is to mount the optics as solid as possible and then isolate the mechanics of the tape transports from any vibration sources. That's why lipstick cams work very well with the remote head. Also a smaller mass, smaller camera will be easier to stabilize..once again, lipstick cameras excel here. just my .02
9 (edited by ronman 2010-01-04 02:38 PM)
Tape transports?
Good lord, man, it's the 21st century. Go solid state.
10 (edited by VKZ24 2010-01-04 02:41 PM)
I built my own version on the I/O Port mount and saved about $50.
I bought this this which is $34.95 for the same head used in the I/O port setup.
I ordered that head, then proceeded to buy the other parts needed to make my own mount.  I bought two of these at AutoZone:
http://fordmustang.biz/pictures/classic_mustang/exhaust/color/muffler_clamp.jpg
To dampen vibration I bought one of these 1/8" thick rubber sewer couplings at Lowe's:
http://www.missionrubber.com/images/SewerCoupling.jpg
I welded the muffler clamps to a 1/8" steel plate, and after a little grinding, and painting I ended up with this:
http://i164.photobucket.com/albums/u9/VKZ24/camera_03.jpg
http://i164.photobucket.com/albums/u9/VKZ24/camera_01.jpg
I think the resulting video is pretty darn stable, but you be the judge:
http://www.youtube.com/watch?v=tTAEwF8z3BM
That's way too ritzy for Lemons. I found a hole big enough for a standard tripod screw, used a couple fat washers, and hold the whole thing laterally in place with zip ties. big_smile
ronman wrote:
Tape transports?
I currently run an Elmo unit, solid state. Back in the early 90's we ran tape transport units on motorcycles with a high degree of luck and\or quality.
I use an IOPort mount, too and when using my newer camera (Sony HDR-HC9) I get vibration a the ends of the straights, and not just in my car but also in the "Estate". This doesn't happen with my older Sony SD camera. Everywhere else on track it is OK for both cameras. I think it is something about the newer camera that makes this happen. Maybe some harmonic with the car vibration or track and the steady-shot feature.
A softer mount might make the problem worse.
I use DV tape, too.  Cheap, minimal compression, easy to archive. But, I think I'll be getting a fancy new dual-camera solid state system this week.
