Topic: refueling procedure?
Where did I see it? Thanks!
The 24 Hours of Lemons Forums → Lemons Newcomers → refueling procedure?
I thought it was in da rules!
It's pretty basic iirc. 1 man on the extinguisher, 1 man spilling gas all over the car. Both must be fully suited with visors down. You cannot work on the car and no one can be in the car while fueling.
you forgot the part about the car had to be running
bob-e wrote:It's pretty basic iirc. 1 man on the extinguisher, 1 man spilling gas all over the car. Both must be fully suited with visors down. You cannot work on the car and no one can be in the car while fueling.
and everyone needs to be smoking a Lucky Strike cigarette
prime suspect wrote:bob-e wrote:It's pretty basic iirc. 1 man on the extinguisher, 1 man spilling gas all over the car. Both must be fully suited with visors down. You cannot work on the car and no one can be in the car while fueling.
And wearing nylons, too!
ecugrad wrote:prime suspect wrote:you forgot the part about the car had to be running
with a can of quick start in your other hand...
I learned from this ...
http://www.youtube.com/watch?v=JCykFawdq40
Make sure you have a drip pan to catch the fuel that you spill all over the place. It is also maditory.
It depends from track to track, but be prepared to have two guys in full driver's gear an extinguisher, and a drip pan at a bare minimum.
Thanks for the info. Gotta find a drip pan.
it's called a "cookie sheet."
Tractor Supply sells giant(like 2'x4') galvanized inch-deep pans for $10.
Thanks Ron, are you going to S.C.?
Yup!
Leaving tomorrow for Charleston with a supercharger for my buddy's DD in tow, and leaving his place early Friday morning to scope a prime paddock spot for the motorhome, trailer, and two diesel trucks.
Come by and say hello if you get a chance . We'll be in the #61 Saab/Mercedes SEL203LEI, 32 valve V6!
Definitely
I'll be walking around a bit with my camera.
Thanks for the tip! Picked ours up last night
So if our car came with two filler necks from the factory, can we have two guys filling gas? If so do we need two guys with extinguishers?
Seriously, '87 Jaguar XJ6s have filler necks on either side and two separate fuel tanks plumbed together. Is dual fuelling allowed?
Why not? We have all seen stranger things at LeMon races. As long as you have two seperate guys in full nomex, two firemen, two drip pans, you should be good.
Somehow appropiate.
That would be if we needed to use BOTH firemen.
