1 (edited by Zanetapos 2024-04-27 11:36 AM)
Topic: [Pending] $5750 Bitchin' 1995 Lexus SC400 - Ready to Race!* Class A
EDIT - I adjusted the price down to better suit Lemons market. Also updated a full mod list (see next comment below).
$5750 - - - 1995 Lexus SC400 Auto - - -  Located ~30 minutes south of Atlanta.
V8 race car that runs, drives, turns, stops. Passed Lemons Tech @ Road Atlanta 2023! [*Fire bottle needs recertification!!!]
Sits on coilovers [ insert brand name here], 4 brand new super mega awesome™ Cosmo Mucho Macho tires, auto trans shift kit upgrade, ARP wheel studs + STEEL lug nuts all around (if you saw us at Road Atlanta, you know why), etc. Previous team estimated current car weight to be ~ 3150-3200lbs.
Car comes with plenty of spare parts including:
- LOTS of brake pads
- spare driveshaft
- rear diff
- ECU
-2x fuel pump ECU
- alternator
- front calipers
- one spare wheel
-misc. gaskets and seals.
(404)-392-8612   -     please reach out by text only.
Photos coming soon.
The story if you actually care: I’m the second “owner” (in race car form). I bought it from a team who ran it regularly in Lemons in the southeast. lt was purchased as a backup car for us for Road Atlanta 2023. I ended up bringing it instead of the primary car due to timeline completion issues. We only ran it one “lap” because: “Hey didn’t that car lose two wheels at Road Atlanta 2023 on turn 2?” Well yes… but it now comes with installed ARP wheel studs and hub-centric rings!
I no longer have a reason to keep two Lemons cars in the garage. With 3 "race cars" now at the house, I need to get rid of one. While this one is arguably the fastest of the three, this is the only one that I have no emotional attachment to.
2 (edited by Zanetapos 2024-04-18 11:01 AM)
Re: [Pending] $5750 Bitchin' 1995 Lexus SC400 - Ready to Race!* Class A
Pictures: https://imgur.com/a/a2XSJxY
More available on request. Videos available of it running/driving as well.
Full mod list stolen straight from the previous owner:
Full custom roll cage with padding and dash bar
Full fire system with certified bottle
5 point harness
Kirksey race seat with back support
Full set of gauges
Functioning cut off switch
steering wheel lock disabled
Electric cooling fans
Oil cooler
Transmission cooler
New radiator
New Power steering pump
New alternator
18" Nissan wheels
Coilovers
Cold air intake
Fire block installed
Hood pins
Big brakes from LS400
Ducted brake vents
New toe links
New trailing arms
New transmission mount
New differential bushings
New rear calipers
SS brake lines in front
New master cylinder
New brake booster
New wheel bearings
New racing brake fluid
Shift kit in transmission
Lexan windshield, and back windows
Significant weight reduction all over
Carfax Report Added!    https://imgur.com/a/S9uwrT9
Q: what trans shift kit was used?
The previous owners/team did all of the work excluding the wheel studs that I did. They're floating around here somewhere but I have zero doubts on the work that was done. They're a capable team and are racing a different car now.
Unfortunately, I cannot be sure the exact kit. From my reading when I was briefly considering a manual swap, TransGo is pretty much the go-to kit. I remember there being one other brand thrown around but it wasn't mentioned on forums near as much.
Thanks - I didn't even know there was a kit. Imanoob.
Your paint job is impressive.
Mine came 'Lemons ready':
https://s5.postimg.cc/3s7hqi1er/20180407_144846.jpg https://s5.postimg.cc/k37lmtlmb/20180407_144856.jpg
bump - come check it out, make me an offer! Point and laugh at my other car!
