Topic: Watch out for imitation grade 8 bolts!
I was working on the Jaggernaut last night and ran across a new problem. When we first got the car we noticed one of our ball joints was bad enough to give 1/4" play at the top of the wheel, so of course we set replacing it as one of our priorities. Jaguar ball joints are really pricey - $70 a piece. After searching the entire damn web we found a "URO Parts" ball joint considerably cheaper. When I went to install the ball joint I noticed the old bolts were grade 8 hardened standard bolts - 5/16" fine thread. The new bolts are marked "8.8" which is a metric hardness rating that's comparable to grade 8. I held the thread of the two bolts together and they matched up perfectly!
I started threading the new bolts in place. Man, they were fitting more snug than the old bolts, but the old bolts did have a lot of corrosion on them. Maybe it's the threads. They look a little rough. Aren't grade 8 bolts usually black or anodized?
SNAP! @#$%ing thing broke off!
Clue #1 - Looks the same size as a standard bolt but has a metric marking.
Clue #2 - Difficult to thread in.
Clue #3 - Poor machine work - not deburred.
Clue #4 - Shiny
Consider yourself warned. Replace the bolts.
BTW, Neither Lowe's nor Home Depot stock fine thread grade 8 bolts.
