Topic: Anybody new a good gm tech in northern virginia?
I have an electrical problem I am trying to solve.  Anyone know a master gm tech in northern virginia I can call?  Please PM.  Like urgently.
Team Pimpalicous
94 Cadillac Seville SLS DOA 10 Capital Offense
87 325 Convertible
Re: Anybody new a good gm tech in northern virginia?
Whats going on? Im not a GM master tech, but I am MECP certified meaning I can play with anything 12V
Hell On Wheels "Totally Not a Rental Car" Chrysler 300
Retreat From Moscow "Traded a Bar Tab for a Wagon" Subaru Legacy
Monterey Car Weeeeak -Dishonorable Mention- "Cocoa Beach A.S.S. Team" Oldsmobile Wagon
Fail Inc Motorsports Intergalactic Headquarters
Was installing kill switch in 94 caddy and now the car won't start.  The starter will now crank, but the dash doesn't work, and the car won't start.  It feels like half the electronics are out.  It is a northstar system.
Team Pimpalicous
87 325 Convertible
Okay, so how did you install the kill switch?
On battery and ignition?
Or did you do battery and alternator?
Because if you did the latter, you may have seriously blown some shit up.
Team FinalGear
I think it was positive lead on battery and electronic block running to alternator.  It was a four post kill switch.  I am however not positive and trying to find out from the dumbass that did it.
Team Pimpalicous
87 325 Convertible
Gotta start with the easy questions
Did you check the fuses?
Do you have a loose/non existent factory connection?
Did you turn the switch back to the on position?
Checked all of the fuses, non were blown.  The kill switch was put in-line, however we also removed the switch and just butt connected the cut cables so there is no more kill switch.
Team Pimpalicous
87 325 Convertible
Have him run through the steps they he took. He may have tripped a fault code in the electronics. Make him run it through and put a dunce cap on his head and make him think about it til he figures out what he fucked up.
Sons of STIG
Judge Jonny, "So, what's the next formerly thought to be immune from winning that will steal the nickels?An MR2? A Fierro (ha ha ha)? A Datsun/Nissan Z? A Camaro?"
Or remove the kill switch from the equasion first to see if the car still starts.  If it does you wired the kill switch wrong.
Pendejo - There is no such thing as a racing budget and if you can't afford to set it on fire and watch it burn while drinking a beer then don't race it.
Make sure all of your grounds are hooked up and that the main harness that comes from under the hood to the dash is connected.
http://www.facebook.com/pages/Top-Fool- … 77?ref=sgm
#34 Save the Tatas Subaru Impreza
2010 Detroit Irony 32nd/Capital Offense 68th/Grand Bull 26th/Rod Blago "FIF"
How do you reset the codes on the car?
Team Pimpalicous
87 325 Convertible
