Topic: Rollcage main hoop design issue
I have a design issue on the roll cage for the Chevette we're building. The car has a frame rail that terminates by the B pillar and I'd like to attach the main hoop to it. Here's the problem, it's located inboard quite a ways. I know it's safest to have the rollcage tight to the body, but I'm not sure the best way to accomplish that.
I figure I have two options. Weld box tubing or build a platform of plate steel out toward the b pillar and weld the hoop to that. I'm not sure there's enough of the car next to the frame rail to weld anything to, this car is basically a tin can and a rusty one at that. The other option is to weld the hoop to the existing frame rail and bend it out to meet the b pillar. I'm not sure how good of an idea it is to have a bend near the legs of the main hoop though.
Pictures so you guys can see what I'm talking about.
Rear view so you can see the space between the frame rail and b pillar.
Side view of the frame rail. I plan on bending those tabs down and using plate steel to cap that off.
