My first compressor was a direct-drive (beltless) model. a Campbell-Hausfeld "Workhorse Series". It made so much noise that I could hardly stand to be in the same garage with it. When it was stolen a few months later, I was actually relieved!
I replaced it with a Campbell-Hausfeld "Excalibur" belt drive model from their "Cast Iron" series, which was *much* quieter. I paid $322 in 1995 at Price Club (now Costco) and am still using it.
If I were to buy a compressor today, I would get an upright model for 220 volts, with the highest CFM rating I could afford. That would allow me to run a sandblaster and to run air tools for longer periods. On the other hand, my current horizontal tank model is on wheels and is portable.
After deciding what style (pancake, horizontal, vertical) you require, look for the highest CFM rating at the pressure you need. Ignore any "horsepower" ratings that you see advertised -- they are total fiction.
Finally, if you decide to run compressed air plumbing around your shop/garage, NEVER, under any circumstances use PVC pipe! In time, PVC will become brittle. Then all it takes is a tiny shock, like a tool falling against it, and it will literally explode with sharp fragments propelled all over your shop. Instead, use iron (or copper if money is no object) pipe with drains at every low point.
