Topic: cage legality, here and other leagues.
I found a very affordable pre-bent weld in cage. But it is ERW and not DOM. The specs on it is 1 5/8" OD .134 wall, which if I remember correctly, passes the Lemons and Chump Car leagues tech inspection.
But will this pass other road racing leagues? SCCA, ITA, NHRA (drag racing), ect.???
I know some places really dislike ERW, but I thought they compensate for that in wall thickness and diameter. Same as they let you run smaller OD and less wall thickness if you choose to run Chrome molly instead of DOM tubing.
oh, also the car will only weight about 2000lbs if that adds to the legality of it.
