Topic: cage main halo too short can it be sleeved?
we may have a problem with the cage.
it is a halo type from " broke dick Racing" we welded the main rear hoop to the halo - turns out is too low for proper helmet clearance..my welder - who is structurally certified - tells me he can add an extension and then sleeve it - the sleeve will attach to the base plate as well as the down tube about 4" above the extension weld covering and encapsulating the extension piece///.
he tells me this is actually stronger?? is this ok or do we need to start over?
also, and I think I already know the answer - the diagaonal cross bar for the rear main hoop can be two pieces joined on a center horizontal support as long as it is one continous run?
is this kosher??
thanks in advance
heres a pic of the extension -- the sleeve will go over this..
