The requirement is for "one main hoop diagonal", which you don't really have.
What you need is a diagonal from top left all the way to bottom right in the main hoop. I'd bet you won't get past tech with what you have. Even if you did... it's not doing such a hot job of protecting your head. You want that extra point above your head.
The "V" you have in the middle does next to nothing, I'd consider removing it for simplicity. The diagonal that you add should be one continuous piece, so plan on notching the harness bar to accomodate it rather than the other way around. Pain in the ass, but that would be the proper way to do it.
