Topic: Caliper mount material
For those of you that have some experience with making mounts for brake calipers or engineering knowledge, what's my best choice for metal when machining an adapter for the mounts?
The 24 Hours of Lemons Forums → Lemons Tech → Caliper mount material
I adapted a set of 13" ZR-1 Corvette calipers and rotors to my Cavalier Z-24 and I used just plain carbon steel 3/8" thick.
Overkill is your friend here. You don't want the caliper to flex under hard braking. Use thick steel for the adaptors and be sure to lok-tite the fasteners.
I've done tons of street cars with 1/4" plate (model As and such), but for a race car heavier is better.. use 1/2" and you'll be more than OK. If you have a milling machine (and a lot of time), you could make a one-piece aluminum mount, but that's a lot of work for a minimal reduction in weight.
Just JB weld it on.
OlCreFoo wrote:For those of you that have some experience with making mounts for brake calipers or engineering knowledge, what's my best choice for metal when machining an adapter for the mounts?
Just JB weld it on.
I dunno if I'd trust JB Weld for this, unless it was reinforced with duct tape.
I agree, using 3/8" will work just fine. The cast caliper will shatter before you loose the structural integrity of the carbon steel. Make sure all bolts nuts and washers are Grade #8 that would be the weakest point in your build.
Toyota uses 3/8 plate in their design when they went to larger rotors on their 87 MR2s. Just make sure you can stop, I would hate to be in front of you if you can't:D
JB weld, duct tape AND pink zip ties will work best.
Pen
Pen
might add a few sheet metal screws, too
just for luck........................................
ha you only need that much when attaching 2 4 piston calipers to a 6" rotor on a 1200lb car.
Sounds like it's nothing super fancy required. I'll see what's laying around my brother's shop and get a supply of pink zip ties for him. I'm sure his duct tape and JB Weld supply is consistent. Maybe even find two more sets of calipers and try to get a triangle going. Apparently there wasn't enough beer during my design phase. VWdmc seems to have that down. There might be enough room...
Home Depot is a great source of caliper bolts....the galvanized carriage bolts are a bargain....or use the leftovers from the Chinese bicycle you assembled for the kids at Christmas...don't forget the Juicy Fruit....don't want the bolts vibrating loose...
yeah cause loctite is a formula derived from bubble gum, make sure you use the long lasting kind, it is an endurance race!
