Topic: $250 Ready-to-race radio kit - Now with GoPro connections!
UPDATE 06/16/22:
I've been keeping the list up to date as listings go out of date.
I've also the Btech radios in favor of Radioddity GM-30's as the USB-C charging is a lot more flexible. They're also easier to work with and generally seem like a better radio.
UPDATE 06/06/21:
2 quick notes based on recent conversations with people who've bought from the lists and had a little trouble:
1) There is a short adapter cable that comes with the PTT/radio harness. This needs to be used to connect the helmet kit. The helmet kit is configured for CTIA pin wiring, while the PTT/radio harness is configured for OMTP pin wiring. The adapter cable switches up the the wiring so they work together.
2) When setting up the GMRS radios (not applicable to the MURS radios) make sure to go into the settings and change your output power to HIGH. Even with an external antenna you're not gonna get very far on the LOW power setting for GMRS. Probably fine for in the pits, but you definitely will have issues getting out and back to a car on track.
UPDATE 04/19/21:
I've added another option for radios. The Radioddity GM-30 is a fully Part-95e licensed radio, just like the BTECH GMRS-V1. There's 2 reasons I added it and 1 reason I haven't completely replaced the BTECH.
I added the GM-30 because 1) they're a bit cheaper. 2 is the minimum you need (pit + car) and you can get the GM-30 pair for $80 with a programming cable, vs $70 for one Btech and 2) they're charged via USB-C, so powering them in-car is a lot easier with a simple 12v->5V buck converter, which they're making now with a direct USB-C cable.
I didn't remove the Btech (yet) because the GM-30 is not yet supported by Chirp for programming. I also don't actually have one in hand to test yet, but the reviews in general are pretty good.
SO, if you want to have a cleaner install or cheaper (but still full-featured) radios, try out the Radioddity GM-30 pair from the list. If you want better programming support (for now) stick with the BTECH.
UPDATE 8/24/19:
Since everything is now 3.5mm TRRS connectors it seemed like it should be super easy to get the audio from the helmet and radio to record to the in-car GoPro Hero4 I run. And it was! Here's the misc. cables you'll need to do so with one of the below kits: http://a.co/7jhljyO
Here's a video of the whole kit set up: https://www.youtube.com/watch?v=-lLbYXVCD70
UPDATE 8/15/19:
I recently went back to look for easier connectors for this kit and surprising found a setup that would work with the the standard TRRS plugs found on the combo earbud/mic cables for most smart phones. I've updated both the Amazon idea lists below and the lists here to reflect the changes.
Original Post
Okay, since there's a couple of threads active on the topic now, I figured I'd make a full Amazon idea list of our radio setup. It is essentially plug and play (there is 1 modification required, you just have to remove a connector pin from a cable with angle-cutters). It runs on GMRS so you REALLY SHOULD get a license. Seriously, it is stupid easy. But other than that if you can change the channel on your TV you can use these radios.
Anyway, here's the setup:
GMRS Endurance Racing Radio Kit
http://a.co/90kmxPM
It includes:
2x Radioddity GM-30 handheld radios (plus programming cable)
1x 12v -> 5V USB-C buck converter to power the radio from the car
PLUS
1x Mag-mount antenna
4x Helmet kits
1x Radio harness
1x radio holder for mounting in the car
1x Helmet extension cable (the PTT button cable on the radio harness is short, so you'll need to mount the radio on the dash or near the steering wheel, thus the extension cable to get back to the helmet)
Feel free to ask questions, but for the most part it is pretty self explanatory. Oh, and please do read the notes on each item in the list.
MURS Endurance Racing Radio Kit
http://a.co/1s1Sstq
It includes:
2x BTECH MURS handheld
4x Helmet kits
1x Radio harness
1x Battery eliminator (lets you plug the car radio into a 12 volt outlet in the car. You may need to get one of these separately)
The differences are:
Positive: You don't need a license to use the MURS kit.
Neutral: All the radios are limited to 2 watts, unlike GMRS radios which allow for radios up to 50 watts, but that's kind of moot because my other kit only has 2 watt radios as well.
Negative: I have no idea how crowded these channels are. You're limited to the 5 channels that MURS has instead of the 20-some-odd for GMRS
