Topic: automatic. siftless or not?
The Jag will have an automatic.. two of the prospective racers have never driven a manual and I don't want them to learn at the race track. (Sigh, I guess the manual will have to stay on the shelf for a while) I'll just remove the clutch pedal so no one confuses it with the brake)
Anyway should I put the kit in to turn the transmission into manual shifting mode?
The stock trans shifts at 5000 automatically but the engine doesn't develop full power untill nearly it's 6500 red line..
With the shift kit you can hold it to shift at whatever RPM you want.
(actaully kit is a overstatement since it's just an extra ball and a little epoxy I put in the valve body)
Yeh, either case will get a giant cooler..
