Topic: Engine weights. For real - someone else did it. All you need.
from: http://www.bacomatic.org/~dw/library/txt/engfyi.htm
Engine Weight/Size FYI version 06.02.18
by Dave Williams, dw32@angelfire.com
It isn't really a Frequently Asked Question, so I'll call it an
"FYI", For Your Information. This was originally a list I'd compiled
long ago on paper, then moved to the computer, then posted on the net
as a response to some questions. It wound up being popular, but since
I didn't keep track of the origin of the data there was some debate as
to how accurate the list was. This new improved list has origins
where I could find references; what doesn't have an origin is stuff
from my original list.
You'll sometimes see more than one weight listed. Some weights are
for just a long block, some are complete and ready to run, and of
course everything in between. Some engines varied in weight during
their production runs - for example, some later Chevy V8s use thinwall
blocks and aluminum heads.
As of version 94.06.01 engine dimensions have been added. Since the
shape can vary quite a bit within the maximum limits this data isn't
very useful, but many people have requested it.
As of version 00.02.04 transmission weights have been added.
If you don't see something listed, it's because I don't have that
information. What I have is here. I don't have a secret hoard of data
sitting to gloat over.
If you have any figures you'd like to contribute, please send them to
me at one of the following addresses:
dw42@angelfire.com
-or-
PO Box 181, Jacksonville AR 72078-0181
All contributions will be fully credited.
weight
engine pounds ref. comments
ABC Dragonfly aero 650 (87) 1917 9-cyl radial
Alfasud flat-4 240 (2) (19) "complete"
Alfa Romeo SOHC V6 375 (2)
Alfa Romeo 415/85T 279 (31) F1 four, '87 season
Alfa 155 V6 TI 242 (75) BTCC Class 1 race engine
Alfa Romeo Type 33 V8 286 (137) 2000cc DOHC, Chiti design, 1967
Alfa Romeo 1600 261 (150) (with cams, generator, distributer, oil,
etc but no manifolds or carbs)
Allison V12 1160 (160) 1710 CID, 1400 HP aircraft
Allison V-1710-G6 V12 1595 (174) 1710 CID, supercharged, 1250hp, 1941
Allison T63 turbine 150 (230)
AMC V8 540 (late design V8s)
AMC V8 600 (early design V8s)
AMC 6 500 (early design six - 199)
AMW F-440 86 (78) SAE F440 spec motor, 2 cyl
Armstrong-Siddely 1180 (203) "Python 3" 2736KW aero turboprop
ATS 1.5L GP V8 247 (137) DOHC, Chiti design, 1966
Audi 2.0 L4 335 (2)
Audi 5 364 (2) (non-turbo)
Audi 80 1300 230 (2)
Audi 100 1500 240 (2)
Audi V6 2.8 354 (190)
Austin C-series L6 562 (2) ('56 Austin-Healey 100-6)
BL "B" L4 OHV 335 (2) British Leyland
BL "E" L6 345 (2) ("complete")
BL "O" L4 OHC 298 (2)
948cc 246 (156) (no indication of dressed or not)
1098cc 253 (156) Midget/Sprite
A-Series 252 (199)
K-Series 216 (199)
BMW M52 3.3,3.5 Big Six 500 (2)
BMW M60 B 40 4.0 V8 468 (17)
BMW M60 Small Six 388 (2)
BMW slant-6 turbodiesel 430
BMW 4.5L V12 607 (2) (50) "Fully dressed" prototype
BMW 4.5L V12 974 (57) iron prototype
BMW 5.0 V12 529 (22) (57) "fully dressed"
BMW V12 (1986) 528 (236)
BMW 3.0,4.0 V8 462 (70) all aluminum
BMW 3.0,4.0 V8 448-468 (79) all aluminum
BMW M105 Diesel 6 2.5L 430 (4)
BMW 2.3 turbo Diesel 408 (21) iron block, alum head, "complete"
BMW S14 four 350 (23) 318i motor
Bollee vertical twin 330 (86) 6 bhp, 600 RPM, evaporative cooled
BRM V12 375 (87) 1965? F1 motor
BRM "290" V12 319 (74) 1992 3.5L Le Mans engine
Benz B2-3BZ, 1917, V8 683 (98) built-up steel, 940 ci, aircraft
Benz V12 946 (250) 300HP aircraft engine, 1921
Bombardier V220 418 (263) Rotax-made 120deg V6, aero w/reduction
Bombardier V300T 462 (263) 120deg V6 aero w/reduction, turbo
Briggs & Stratton 101 (165) 20HP w/electric start, flywheel, exhaust
BSA Lightning 650 138 (193) unit construction 650 twins, 1966-1968.
Buick 1963 odd-fire V6 414 (2)
Buick V6 375
Buick 3.0 V6 '85-up 350
Buick odd-fire V6 367 (245)
Buick even-fire 3.8 380 (245)
Buick 4.1 V6 410 (245)
Buick 3.0 V6 377 (245)
Buick 198 V6, 62-63 354 (245)
Buick/Rover 215 V8 318 (and Olds)
Buick 1961 215 V8 324 (2)
Buick 1953 322 V8 635 (51) OHV V8
Buick 300 V8 400 (242) iron block, aluminum heads, 1964 only
Buick 300 V8 467 (245) 1965 all-iron version
Buick 350 450
Buick 350 V8 450 (247) "lightest of GM's iron V8s"
Buick 401 685 (1) ('59 Nail Head)
Buick 430-455 V8 600 (one ref showed 640) (10 - 600)
Cadillac V-16 1,300 (2) (1931) 45 degree bank angle
Cadillac V16 1938 1,056 (191) 135 degree bank angle, flathead
"Engine weight including clutch and control
and all accessories..."
Cadillac V8 390 720 (1) ('59)
Cadillac V8 472-500 625
Cadillac V8 500 595 (10)
Cadillac 331 V8 699 (2) (1949)
Cadillac Northstar V8 484 (71)
Cadillac Northstar V8 403 (79) (bare, no accessories)
Cadillac Northstar V8 464 (80) (dressed)
Cadillac Northstar V8 404 (155) (without accessories)
Cadillac 4.9L (300 ci) 360 (188) '91 DeVille, w/alt & flexplate
Callaway Indy HH-V8 277 (54) 2.6L Drake design
Callaway "Wee 8" 200 (91) light weight design study
Caterpillar L6 2867 (157) 3406E 600 Diesel 966CID
Chevy Sprint 993cc L3 147 (55) 24L x 20W x 25H (Suzuki mfr)
Chevy 1.8-2.0 L4 302 (4) (39) "J car" pushrod
Chevy Chevette 1.6 SOHC 300 (4) (39) (also Opel)
Chevy Vega L4 285
Chevy II 153 L4 350
Chevy II 153 L4 283 (245)
Chevy Corvair flat 6 300 (244)
Chevy L6 194-250 440
Chevy L6 292 ---
Chevy L6 216/235 630 (2)
Chevy L6 216/235 615 (88) "265 V8 was 40# lighter than 235"
Chevy V6-90 229-4.3 425
Chevy V6-60 2.8, 3.1 350 (2)
Chevy V6-60, 2.8 350 (245)
Chevy small block V8 575 (generic for '60s-'70s motors)
Chevy small block V8 535 (1) ('59 Corvette 283 w/alum. intake)
Chevy small block LS1 460 (185)
Chevy 5.7 industrial V8 434 (182) '99 iron long block w/water pump only
Chevy LT-5 DOHC 5.7 600 (122)
Chevy L98 5.7 V8 600 (122)
Chevy V8 348/409 620 (1)
Chevy V8 348/408 655 (83)
Chevy big block V8 685 Mark IV
Chevy big block V8 --- Mark V
Chevy 454 675 (10)
Chevy 7.4L V8 656 (183) iron, no intake, exh, carb, starter
Chevy 427 ZL-1 550 (35) all-aluminum, "20# lighter than SB"
Chevy 6.5L Diesel V8 644 (183)
Chevy 400 SB 470 (235) aluminum heads and intake, no acc. or wp
Chevy 396 BB 610 (235) iron heads, alum. wp and intake, no acc.
Chrysler 2.2 L4 216 (6) (bare motor)
Chrysler 2.2, 2.5 L4 276 (245)
Chrysler 413 wedge 640 (1) ('59 300-E)
Chrysler 331 Hemi 745 (5) 1955
Chrysler M4 tank engine 5,244 (87) 30 cyl, 5 banks of 6, flathead, WWII
Chrysler 1955 V8 691 (99) Spitfire, 'polyspheric', 300 ci 188 hp
Chrysler 1955 Hemi 729 (99) Firepower 331.1 ci, 250hp, 1x4v
Chrysler 1955 300 Hemi 735 (99) C-300, 331.1 ci, 300hp, 2x4v
Chrysler Patriot 186 (110) gas turbine (part of hybrid EV)
Chrysler CR2A turbine 410 (111) 1964 Turbine Car, 130hp SAE net
Citroen 2.0 Douvrin 4 263
Clerget Rotary Type 9 295 (175) 1917 French 9-cyl radial, Sopwith Camel
Clerget Rotary Model B 380 (256) 1911, 9 cyl radial, 16.3L, 130hp
Continental TSIO-550B 566 (113) turbocharged, aircraft
Continental Voyager 571 (113) turbocharged, aircraft
Cosworth AC V8 ('93) 286 (23,64) 75 degree bank angle
Cosworth HB 75 deg V8 309 (52,63) 23.4L x 23.3W x 20.5H
Cosworth HB Series 6 286 (70) 75 deg V8 595mmL
Cosworth DFV V8 313 (23) 90 degree bank angle
Cosworth DFR V8 308 (63) 90 degree bank angle
Cosworth DFX V8 340 (29)
Cosworth XB V8 260 (29, 89)
Cosworth V8 375 (87) 1965? F1
Cosworth MBA 2.5L V6 242 (61,68) 90 deg V
Cosworth ED 75 deg V8 292 (103) F1, 3 liter 1994
Cosworth 72 deg V10 440 (134) 4.3L 325hp prototype (street)
Cosworth V8 370 (136) 1967, with clutch and injection
Cosworth CR-1 V10 220 (144) 1999 F1
Cosworth YBF 319 (199)
Cosworth DOHC V8 260 (240) circa 1995
Coventry Climax FWMV V8 270 (121) 1963, w/starter & dynamo (2 valve)
Coventry Climax FWMV V8 298 (121) 1965, w/starter & dynamo (4 valve)
Crosley Cobra ('46-'48) 59 (25,26) less starter and generator
Curtiss-Wright
RC2-60-N8 rotary 900 (96)
RC2-60-U10 rotary 325 (96) "heavy fuel" plus 50.2 for flywheel
RC1-60 rotary 192 (96) air cooled, w/all accessories
RC2-60 rotary 266 (96) air cooled, w/all accessories
RC4-60 rotary 417 (96) air cooled, w/all accessories
RC2-90 rotary 317 (96) air cooled, w/all accessories
RC2-90 rotary 345 (96) water cooled, w/all accessories
RC3-90 rotary 410 (96) air cooled, w/all accessories
RC3-90 rotary 480 (96) water cooled, w/all accessories
RC4-90 rotary 510 (96) air cooled, w/all accessories
RC4-90 rotary 613 (96) water cooled, w/all accessories
RC5-90 rotary 605 (96) air cooled, w/all accessories
RC5-90 rotary 740 (96) water cooled, w/all accessories
RC6-90 rotary 710 (96) air cooled, w/all accessories
RC6-90 rotary 860 (96) water cooled, w/all accessories
RC2-60 U5 rotary 280 (96)
G series Cyclone 1163 (181) radial, geared, 54-1/4 dia, 43-1/4 long
G series Cyclone 1068 (181) radial, direct, 54-1/4 dia, 43-1/4 long
F series Cyclone 1070 (181) radial, geared, 54-1/8 dia
F series Cyclone 975 (181) radial, direct, 54-1/8 dia
Curtiss V12, 1920 1086 (98) 1650 ci, steel with Al crankcase
Curtiss D12 aero 698 (251) 400hp V12, 1920?
Daimler-Benz 605 1662 (176) inverted V12, 1937, 2179 CID, 1475hp
Daimler 4.5 V8 400 (241) "over 400 pounds"
DeSoto 383 630 (1) ('59)
DeSoto V8 675 (5) (276-341 CID, '50s)
Detroit Diesel 6 2448 (37) (old design)
Detroit Diesel 6 1848 (37) (new Penske/Mercedes design)
Dodge Colt (Japanese) 212 (245) also Plymouth Champ, 1.4, 1.6L four
Dodge V8 645 (5) (241-325 CID, '50s)
Dodge 361 625 (1) ('59)
Dodge Viper V10 716 (24) (30) with accessories
Dodge Viper V10 ('97) 648 (133) 40# lighter block, 14# lighter heads
Dodge truck V10 816 (30) ("about 100 pounds heaver")
Dodge truck V10 836 (34) ("about 120 pounds heaver")
Dodge truck V10 816 (128) "dressed weight"
Drake DT-160 Indy V8 420 (138) 1978 model Meyer-Drake racing engine
Drysdale 750cc V8 143 (214) with carbs, no radiator
Ducati 864cc V2 131 (192) Electric start side case w/o starter
Edsel 361 680 (1) ('59)
Fairbanks-Morse 40,840 (126) 2894 CID, 12 cyl, 12,408hp locomotive
Falconer V12 523 (112) aluminum, small block Chevy based
Ferrari 312T 397 (2) (V12 3.0L racing engine)
Ferrari "250" V12 382 (2)
Ferrari V12 ~300 (23) 65 degree bank angle, 1992 F1
Ferrari 456 V12 517 (32,65) 65 degree, 5.5L, 1992
Ferrari "036_ F1 V12 310 (66) 65 deg, 3.5L
Ferrari "291" F1 V12 275 (66) also E1A-92, 65 deg
Ferrari E1A/92 F1 V12 308 (70) 65 deg
Ferrari F50 4.7L V12 432 (90) iron block, titanium rods
FIAT/Ferrari Dino V6 285 (2) (model 206)
FIAT/Ferrari Dino V6 296 (2) (model 246)
FIAT 8V circa 1952 372 (224) carbs, clutch, headers. 70deg V8, OHV
Fiat Twin Cam 272 (199) four cyl, from Fiat 128
Folan V-twin 95 (228) w/everything but the carb
Footwork/Porsche FA12 396 (76) F1 V12
Ford Model A four 475 (225)
Ford 1600 Kent OHV 260 (234)
Ford 1600 CVH 282 (49) (US Escort)
Ford 2.0 Pinto SOHC L4 320 (234)
Ford 2.0 Pinto 286 (245)
Ford 2.3 Pinto 328 (245)
Ford 2.3 Lima/Pinto L4 418 (2) (also 2.0, 2.5)
Ford 2.3 Lima/Pinto L4 307 (18)
Ford 2.3 Lima/Pinto L4 450 (2) (turbo)
Ford 2.3 L4 Turbo 380 (162) Turbo T-Bird engine w/turbo, flywheel
Ford 2.3 Polimotor 152 (12) plastic motor, experimental
Ford 2.3 Polimotor 168 (55) plastic motor, experimental
Ford Germany Taunus V4 205 (2) (and SAAB V4)
Ford/SAAB V4 230 (245) 1.5, 1.7L
Ford England Essex V4 327
Ford Zetec-SE 1.3 DOHC 202 (107) 1996 Fiesta
Ford Zetec 238 (199)
Ford Germany 2.0-2.8 V6 305
Ford Cologne 2.0-2.8 V6 380 (234)
Ford Capri/Pinto V6 365 (245) 2.6, 2.8L Cologne
Ford England Essex V6 379 (2) (3 liter)
Ford England Essex V6 430 (234)
Ford England Essex V6 405 (238)
Ford 3.8 V6-90 351 (4) (w/start, alt, less clutch)
Ford 3.8 V6-90 311 (18) ("fully dressed")
Ford 3.8 V6-90 298 (126) "complete"
Ford 3.8 V6 402 (245)
Ford Duratec 2.5/3.0 V6 360 (45) ("fully dressed")
Ford CDW27 60 deg V6 365 (47) "as delivered to assembly plant"
Ford/Mazda Mondeo V6 225 (64) 60 deg, all aluminum, 4v
Ford Taurus SHO 3.0/3.2 465 (153) Taurus SHO V6
Ford 170-250 L6 385 (except Australian w/aluminum head)
Ford 4.2 V6 488 (161) flexplate and front dress, no A/C
compressor. Shipping wt w/skid
Ford 3.8L V6 376 (231) 1998 Mustang, dressed (dry)
Ford flathead V8 525 (124) 1932 model, integral b'hsg, iron heads
Ford flathead V8 569 (1) ('53 239 CID)
Ford flathead V8 616 (241) "complete with clutch and gearbox"
Ford Cosworth DFV 353 (2) (racing engine, DOHC, 3.0L)
Ford 255 Windsor 468 (4)
Ford 289/302 V8 460 (168) (late 5.0s are a bit lighter)
Ford 221-302W 460 (48)
Ford Indy 255 pushrod 360 (120) all aluminum, 1963
Ford Indy 255 DOHC 400 (120) 1964, later known as Foyt Coyote V8
Ford 5.0 V8 450 (109)
Ford 5.0 V8 411 (171) 89 Mustang 5.0 GT (dry) inc: manifold,
carb(?), headers and alternator. Not
inc: starter, smog pump, power steering
pump, AC compressor, flywheel
Ford BOSS 302 500 (48)
Ford 351 Cleveland 550 (48) (includes BOSS and Australian 302-C)
Ford 351 Windsor 510
Ford 351 Windsor 525 (48) (168)
Ford 351M-400 575 (48)
Ford Y block V8 625 (272-312 CID)
Ford FE big block 650 (332-428 CID)
Ford FE big block 670 (1) ('59 352 CID)
Ford FE 625 (48)
Ford 427 SOHC 680 (48)
Ford 429/460 V8 640
Ford 429-460 720 (48)
Ford 460 V8 720 (10)
Ford BOSS 429 680 (iron block, aluminum heads)
Ford BOSS 429 635 (48)
Ford 4.6 SOHC 530 (93) iron block, aluminum heads
Ford 4.6 SOHC 473 (72)
Ford 4.6 SOHC 600 (168) (Mustang)
Ford 4.6 DOHC 464 (72) "9 pounds lighter than SOHC"
Ford 4.6 DOHC 437 (77) without accessories
Ford 4.6 DOHC 521 (94) aluminum block and heads
Ford 4.6 DOHC 576 (168) (Mustang)
Ford 4.6L (SOHC) 529 (231) w/flywheel 1998 Mustang, dressed (dry)
Ford 4.6L (SOHC) 492 (231) w/flexplate 1998 Mustang, dressed (dry)
Ford 4.6L (DOHC) 535 (231) 1998 Mustang, dressed (dry)
Ford Taurus SHO 3.2 V8 390 (229) Taurus SHO V8, no accessories
Ford Triton V10 635 (128) "dressed"
Ford/Seimens 75hp 192 (108) 3-phase electric, with gear drive
GM CD5-2 2-stroke 165 (42,68) Orbital patent, prototype
GM Rotary Engine 255 (13) cast iron, 1972 PR weight figure
GM Rotary Engine RC206 345 (14) aluminum, 1974 PR weight figure
GMC 261 L6 (216-235) 544 (43) "25 lbs lighter than flathead Ford"
GM Ultralite engine 173 (67)
Garrett/Allied Signal 125 (108) hybrid EV gas turbine w/generator
General Electric T-58 ~200 (115) 1100hp, helicopter turbine
Geo 3 135 (232) (bare)
Gnome rotary 290 (255) Model N "Monosoupape" 9 cyl,
Gravely tractor 1cyl 65 (164) 1916-1976, minus manifolds and carb
Gurney-Weslake V12 370 (33) Eagle AAR, 60 degree
HKS F1 3.5 V12 363 (23) Formula 1, 5 valve per cyl.
HS Performance 2.0 V8 160 (63) (2xYamaha FZR1000) 488L x 552W x 478H
Hall-Scott 6 cyl 825ci 565 (97) Merc type A/C engine, >WWI Fageol racer
Hall-Scott Model A-7a 410 (260) 4 cyl inline, 606 CID, 125 HP@1400 RPM
Hart V10 F1, 72 deg V 300 (63) model 1035, 622L x 560W x 535H
Hart 10.35 300 (64) 622L x 560W
Hart 420R 2.0L 245 (106) 1994, also Barker-Hart
Hispano-Suiza V8 330 (86) 1915 aircraft engine, water cooled
Hispano-Suiza V8 32CV 540 (86) 1919 6.6 liter car engine
Hispano H, 1918 632 (98) aircraft, 1127 ci, steel w/Al crankcase
Honda 1.5L V6 286 (237) 1983 F1 engine, twin turbo
Honda RA122E 75 deg V12 330 (23) Formula 1
Honda RA1/22E/B 352 (70) (est. weight) also RA121E
Honda RA168E F1 V6 329 (119) 80 deg, 1500cc
Honda 3.5L 72 deg V10 331 (40, 52) 24.4L x 21.7W x 21.3H Formula 1
Honda 75deg V12 340 (41) 1993 Formula 1
Honda 24V V6 491 (55) Acura Legend motor
Honda CBR 600 F2 125 (102) motorcycle
Honda B18B four 326 (131) 1995 Civic
Honda B20B four 318 (131) 1997 Civic
Honda Civic 1200 161 (151) 1974 Civic, excluding clutch and
radiator but including weight of coolant
water and lubricant
Honda Civic 1500 205 (151) 1974 Civic, as above
Honda CVCC 1500 227 (151) 1974 Civic, as above
Honda CBX1000 Six 235 (218) 1978
Honda CBR 600 F2 130 (167) motorcycle (estimated)
Honda CBR 600 F2 140 (173)
Honda CBR 600 F2 138 (227) w/o without carbs, ignition, or exhaust
Honda CBR600F 139 (192) (1987-1990) 139#
Honda CBR600F2 132 (192) (1991)
Honda Hurricane 1000 187 (192) 1988 motorcycle, water cooled four
Honda CBX 1000 238 (192) from shop manual
Honda CR500 66 (169) 2 stroke single, 491cc, 65HP
Honda Hurricane 600 140 (208) 1987
Honda CB650, 1980 157 (211) air cooled four, SOHC
Honda RC160 128 (212) air cooled four, F1, 250cc, 1959 (race)
Honda CBR250 100 (212) water cooled four, 250cc, 1987 (street)
Honda XR250 68 (213) 1984, radial four valve
Honda XR200 67 (213) 1984, radial four valve
Honda XR200 60 (213) 1983, radial four valve
Honda CR250, 87 52.5 (217) w/k-start/oil
Honda CR250 45 (217) w/radiators/no carb late 80's
Honda XL250, '78 79.4 (217) w/carb early engine
Honda XL250, 79-82 72 (217)
Honda XR250, 85 70 (217)
Honda XR200, '80s 53 (217)
Honda SL125, '71 50 (217) w/carb
Honda XL350, '73-78 95 (217) w/carb
Honda XR500, '79 87 (217) w/carb
Honda Hawk 650, '89 135 (217) w/o carbs
Honda CX500 114 (214) without radiator, with carbs
Honda CX500 141 (220) with radiator, exhaust, carbs, airbox
Honda CX650 123 (214) without iron engine mounts
Honda NS400R 99 (219) 2 stroke triple, complete
Honda GX22 7.5 (221) 4stk OHV single, industrial
Honda RC181 350-4 155 (261) 1967 F1 racing, complete
Hooper 994cc V4 92 (73) two stroke, stepped piston, prototype
Hooper 290cc twin 54 (73) two stroke, stepped piston, prototype
Husaberg 500, early 57 (217)
Husaberg 600 63 (169) SOHC 4 stroke single, 595cc, 65HP
Husqvarna 510 TE 78 (205) SOHC 4 stroke single, 510cc
Husqvarna 575 72 (169) SOHC 4 stroke single, 577cc, 62HP
Husqvarna 630 72 (169) SOHC 4 stroke single, 633cc, 70HP
Ilmor 80deg V8 325 (29)
Ilmor 2175A 72deg V10 281 (59) 592.5mmL, 519mmW, 555mmH
Ilmor 2175A 72 deg V10 268 (70)
Ilmor V-8-A Indy 325 (69) 1992 Galmer Indy car, 90 deg V
Ilmor 265A 80 deg V8 325 (84)
Ilmor 265D 82 deg V8 272 (84)
Ilmor 265D 82 deg V8 272 (210) Indy
Ilmor 265B V8 297 (210)
Infiniti 4.5 V8 551 (71)
Infiniti Q45 V8 509 (72) "45 pounds heavier than Ford DOHC"
Infiniti Q45 V8 529 (77) "65 pounds heavier than Ford DOHC"
Isuzu 1.8 Diesel L4 384 (4)
Isuzu 1.8 gas L4 311 (4)
J.A.P. KTW 90 (248) V2, 980cc, 1909 (Morgan car) flathead
J.A.P. JTOR 133 (248) V2, 996cc, (Morgan Car) OHV
J.A.P. LTOW 128 (248) V2, 1096cc, (Morgan Car) OHV
J.A.P. Type 4B 59 (249) speedway single, 496cc
Jabiru 80hp aero 123 (114) flat-4, air cooled
Jaguar V12 680 (57)
Jaguar V12 792 (236) 1986 model
Jaguar V12 640 (186) "test bed condition"
Jaguar/Orbital 3.2 V6 359 (61) supercharged two stroke
Jaguar 4.2L six 604 (105)
Jaguar XJ220 V6 427 (73) complete w/turbos, wiring
Jaguar AJ6 4.0L 531 (118)
Jaguar AJV8 4.0L 441 (118) "fully dressed"
Jaguar 3.4-liter XK 576 (148) for the 340 sedan, minus fan, air
cleaner, clutch, and transmission, and
without any fluids, but with flywheel,
electrical equipment, and exhaust
manifolds.
Jaguar 3.8 six 592 (148) dress as above
Jaguar 4.2 six 605 (148) dress as above
Jaguar 5.3 V12 612 (148) dress as above
Jaguar 5.3 V12 680 (148) fully dressed for installation
Jaguar 3.6 six 430 (186) "test bed condition"
Jawa Speedway 500cc 67 (194) about 55 hp and max rpm is 8600
Judd V10 286 (22) 72 deg V, F1, 630mm long
Judd KV V8 242 (64) 90 deg F3000 1992
Judd GV 72 deg V10 273 (70) 630mmL
KTM 600, '89 73 (217)
KTM330 59 (169) 2 stroke, 368cc single, 64HP
KTM520 63 (169) SOHC 4 stroke single, 510cc, 56HP
KTM LC4 500 73 (204) 4 stk single, 4V, water cooled, prototype
KTM 80 65 (205) 4 stk single, 4V, water cooled, prototype
Kawasaki H1R, H2R 120 (9) 3 cyl, two stroke MC
Kawasaki EX500 twin 115 (201) estimated
Kawasaki Ninja 750 147 (209) 1986, without carburetors
Kawasaki ZZR 1100 163 (214) ZX 11 in the USA
Kawasaki KLX250, 80? 74.5 (217) w/carb
Kubota D905-B Diesel 250 (125) 3 cyl, water cooled, with starter
LPE 400 Series Turbo 370 (113) aircraft, 400 CI, SBC based, alloy
LPE 600 Series Turbo 560 (113) aircraft, 670 CI, BBC based, alloy
Lamborghini/Chrysler 299 (8) (1992) V12 Formula 1 motor
Lamborghini 80 deg V12 330 (70) 1991-1992 V12 F1
Langley Aerodrome 200 (126) 5 cyl radial, 1903, 52hp
Laverda 750 SF/SFC 145 (215) four stroke triple
Laverda 750 SF/SFC 178 (214) four stroke triple
Laverda 1200 Triple 183 (214)
Le Rhone "Super Rhone" 340 (177) 9 cyl radial (non-rotary) 120hp, 667CID
Lexicon TRJ-300 110 (114) centrifugal turbojet, aircraft
Lexus 4.0 V8 470 (71)
Lexus 4.0 V8 464 (77)
Liberty V12, 1917 856 (98) 1400+ ci, all steel, aircraft engine
Liberty V12 786 (258) dry weight, 1649 CID, 400hp
Lincoln 430 740 (1) ('59) (also Mercury 430)
Lotus 907 (Esprit) 275 (3) inc. alt. & starter, no clutch
Lotus Project 618 V8 465 (117) Esprit V8 prototype, w/AC, PS, alt.
Lycoming 36 cyl radial 6050 (87) WWII, 127 liters, 4x9, water cooled
Lycoming XR-7755 6050 (178) 1943, 36 cyl radial, 7755CID, 5000HP
Lycoming IO-540 515 (113) aircraft
Mallory rotary 188 (87) 400hp, eccentric-vane
Marmon V-16 931 (2) (1931)
Mazda 12A and 13B 260 (109)
Mazda 10A rotary 224 (20) (Cosmo) (bare)
Mazda 10A rotary 268 (20) (R100) (bare)
Mazda 10A rotary 190 (27) (R100) (without thermal reactor)
Mazda 10A rotary 280 (27) (R100) (with thermal reactor)
Mazda 12A rotary 348 (20) (RX7) (with oil and water)
Mazda 12A rotary 356 (20) (Japanese model turbo, EFI)
Mazda 12A rotary 275 (85) (w/flywheel, t.reactor, no alt.)
Mazda 13A rotary 301 (20) (R130 Lucia - Japan only) (bare)
Mazda 13B race 242 (95) 2-rotor race motor, with accessories
Mazda 13G 3-rotor race 319 (95) 3-rotor race motor, with accessories
Mazda 13J 4-rotor race 396 (95) 4-rotor race motor, with accessories
Mazda 13B FI 337 (197) 1986-1992 160hp (w/oil and water)
Mercedes SOHC V8 alum. 452 (2)
Mercedes SOHC V8 iron 540 (2)
Mercedes 5.6L V8 467 (57) 1987
Mercedes OM 615 Diesel 447 (16)
Mercedes M291 flat-12 374 (66) with starter, alt, exh, no clutch
Mercedes 2.8/4.2 V6 331 (127) 1997, SOHC 3V, "shipped for assembly"
Mercedes inline six 441 (127) 1995 and back
Mercedes 500I V8 305 (46) 1994 pushrod Turbo Indy motor (Penske)
Mercedes/Ilmor Indy V8 273 (57, 60) 72 deg V Turbo Indy motor
Mercedes/Ilmor DOHC V8 280 (89) 1995 IC 108 model, no clutch
Mercedes/Ilmor IC108C 280 (130) 1996 DOHC V8
Mercedes 3.2L V6 330 (141) 1997 SOHC, 90 deg, 3 valve
Mercedes 5.8L V12 490 (143) 1997, 3 valve
Mercedes V10 F1 290 (210) 1994
Mercury Marine 2000 331 (14) 200hp, 2 stroke, 142 CID, w/foot
Mercury Marine 1750 350 (14) 275hp, 2 stroke, 122 CID, w/foot
Miller 91 (1926) 330 (44) predecessor to Offy four
Mopar Slant Six 475
Mopar 273-340 "A" V8 525
Mopar 360 "A" 550
Mopar 361-383-400 V8 620 (5)
Mopar 413-426W-440 V8 670 (5) (10)
Mopar Street Hemi 765 (690 bare)
Mugen V10 330 (23) 72 degree bank angle, F1
Mugen V10 341 (70) 72 degree bank angle, F1, 1991-1993
Mugen V8 255 (64) 90 deg F3000 (late motor)
Mundy Trident W-12 325 (85) proposed 1965 F1, not built
Napier Nomad flat-12 3580 (87) aircraft, turbo-compound
Napier Lion W-12 930 (87) aircraft, 1918, water cooled
Napier Deltic, 1950 11000 (87) general use, 18 cyl
Napier Deltic, 1966 15000 (87) intercooled, turbo version
Napier Sabre H-24 2000 (202) twin crank aero, sleeve valve
Nissan CA20 FWD 269 (4) belt cam
Nissan Z20 NAPS-Z 2.0 346 (4) RWD chain cam
Nissan VRT35 GTP V12 341 (66) 70 deg prototype 660L x 577W x 533H
Nissan Maxima V6 3.0 264 (145) 60 deg, racing SR2
Nissan VG33 3.3L 433 (223) un-dressed, SOHC V6
Nissan L series 265 (245) 1.6 and 1.8, and NAPS-Z
Nissan 3.0 V6 360 (245) 300ZX, Maxima, and pickup. SOHC
Offenhauser 252 355 (142) early '60s, aluminum/magnesium four
Olds 215 V8 318 (same as Buick/Rover)
Olds 215 V8 345 (170) 1962, 2bbl, dry weight
Olds 304 "Rocket" V8 671 (2) first Olds V8, 1949
Olds 304 Rocket V8 680 all accessories, no flywheel
Olds straight-8 614 (2) '40s motor
Olds 330 J2 700 (first generation V8)
Olds 330-400 560 (5) low deck, w/accessories, no flywheel
Olds 394 725 (1) ('59)
Olds 371, 394 760 (5)
Olds 400-455 620 (5) high deck w/accessories, no flywheel
Olds 455 605 (10)
Olds 262 V6 Diesel 590 (4) (from GM SAE paper)
Olds DOHC 4.0 V8 463 (80)(dressed) Olds variant of Cad Northstar
Olds Aurora IMSA V8 405 (239) IMSA racing variant
Opel 2.8-3.0 CIH L6 395 (2)
Opel MAXX 973cc 3cyl 182 (132) also used by Vauxhall
Orbital 2.0 L6 220 (82) "dressed" 2 stroke, all aluminum
Otto "Atmospheric" 2600 (56) 1hp, 15 feet tall, model of 1867
Packard 1A-1500 aero 735 (251) 440hp, early '20s
Packard 2500 aero 1100 (251) 800hp, 1925
Peugeot 204 Diesel 272 (11) SOHC, 45hp
Peugeot Douvrin 2.0 4 263 (2)
Peugeot 104 1400 260 (2) includes transaxle
Peugeot Indenor XD-90 415 (16) Diesel, aluminum head and sump
Peugeot 16 valve 316 (199)
Peugeot ES9 J4 3.0L 473 (223) fully dressed, all alloy 24V, 60 deg. V6
Pierce-Arrow V-12 1,130 (2) (1932)
Pininfarina 181 (61) Ethos show car, Orbital 3 cyl
Plymouth 361 640 (1) ('59)
Polimotor DOHC 2.0 L4 150 (53) mostly plastic, development motor
Polimotor L4 179 (106) inc. starter, no clutch or flywheel)\
Pontiac L4 350 Iron Duke, Tech IV
Pontiac Tempest slant 4 470
Pontiac SOHC 6 450
Pontiac SOHC 6 550 (100)
Pontiac 389 V8 650
Pontiac 389 V8 590 (1) ('59)
Pontiac 301 V8 452
Pontiac 301 V8 451 complete with air cleaner and starter
Porsche 914/4 265 (109)
Porsche 911/6 280 (109)
Porsche 911/6 325 (245) with heater boxes
Porsche 911/6 280 (245)
Porsche 912 210 (245) 1582cc
Porsche 914 1679cc 265 (245)
Porsche 914 1980cc 311 (245)
Porsche 4.7 SOHC V8 574
Porsche 4.7 SOHC V8 582 (57)
Porsche 901 6 401 (2) (1963)
Pratt & Whitney ST6B-62 260 (135) 550hp, '67 STP Turbine Car
Pratt & Whitney SB-G 1265 (179) Twin Wasp radial, 1000hp, 48" dia radial
Pratt & Whitney S2A4-G 1070 (179) Twin Wasp Junior, 700hp, 48-1/8" dia
Pratt & Whitney SC-G 800 (179) Wasp Junior, gear drive, 525hp, 46-3/4"
Pratt & Whitney SB 596 (179) Wasp Junior, 450hp, 46-3/4" dia radial
Pratt & Whitney SIE-G 1015 (179) Hornet, gear drive, 800hp, 54-7/16"
Pratt & Whitney S5E 920 (179) Hornet, 700hp, 54-7/16" radial
Pratt & Whitney R-2800 2350 (180) Double Wasp, 2400hp, 2800CID, 1939
Pratt & Whitney R-4360 3600 (259) Wasp Major "corncob", 4363 CID, 3500HP
Rambler 327 V8 600
Rambler 327 V8 670 (1) ('59)
Renault 2.0 4 Douvrin 263 (2)
Renault 2.8 V6 375 (2) (also DeLorean, Peugeot, Volvo)
Renault EF-1 395 (2) (racing version of P-R-V V6)
Renault V10 308 (23) 67 degree bank angle, F1
Renault V10 331 (52) 67 deg
Renault RS3B V10 301 (70) 67 deg
Renault D7F 1.1L 180 (123)
Renault E-series 1.2L 238 (123)
Repco-Brabham 3.0 V8 340 (241) early '60s F1 engine based on Buick 215
Rolls-Royce 6.5 Wankel 930 (51) tank engine
Rotax 5 Valve 600cc 90 (192) single cyl, over 60 HP
Rotax 504 single 95 (216) four stroke single
Rotax ATK560 91 (217) early model
Rotax-Aprilia 5-v 106
Rover 3500 V8 318 (same as Buick)
Rover 3.0 SOHC L6 432 (2)
Rover 2000 four 312 (36) 1960s engine
Rover KV-6 2.5L 335 (117, 123, 233) "fully equipped"
Rover KV6 2.5L 339 (223) fully dressed, all alloy 24V, 90 deg. V6
SAAB V4-60 206 (2) (also Taunus, Ford)
SAAB slant-4 290 (2) (also Triumph TR-7)
Studebaker 289 650
Studebaker six 403.5 (187) 169.9 ci Champion 1948 to 1954
Subaru 2.2L 269 (139) aero conversion
Subaru flat-12 F1 331 (52) Formula 1, Moteri Moderni
Subaru 1.8L four 188 (245) pushrod, 1781cc
SuperLight 180 SL 210 (114) Mazda 13B-based, aircraft, alloy housings
Suzuki Cultus 3 cyl 139 (7,38, 207) (Geo Metro, Chevy Sprint)
TAG TTE-PO1 330 (237) 1983 twin turbo six, GP racing
Toyota 1G-EU 2.6 L6 340 (27) with oil and coolant (SOHC)
Toyota 1G-GEU 2.0 L6 355 (140) with oil and coolant (DOHC)
Toyota 4M Hemi L6 400 (27)
Toyota V6 469 (81) '92 Camry iron V6
Toyota V6 3.0L 401 (81) '94 Camry aluminum V6 1MZ-FE
Toyota RV8A Indy V8 225 (116) '96,as used in Gurney Eagle
Toyota R32V GT1 V8 352 (144) twin turbo DOHC race engine, 1988
Toyota 4A-GE four 340 (200) iron block
Toyota 2TC, 2TG, 3TC 262 (245) '71-up, 1.6-1.8 four cyl, 2TG is DOHC
Toyota 1A, 3A, 4A 225 (245) Tercel, MR2, '84-up Corolla, '85-up
Chevy Nova
Toyota 18R, 20R, 22R 318 (245) pre'86 Corona, Celica, and pickup.
also 18RC and 18RG
Toyota 3SG 293 (245) Celica DOHC 16 valve
Triumph slant-4 290 (2) (also SAAB 99)
Triumph 2000 L6 403 (2) (Spitfire, 2.5 TRs)
Triumph Stag V8 446
Triumph Bonneville 650 120 (192) motorcycle
Turbonique S-12 60 (222) 350hp turbine, monopropellant fuel
Volvo V6 350 (245) 90 deg, aluminum, DeLorean, Peugeot,
Renault
VW flat-4 air cooled 200
VW flat-4 air cooled 215 (109)
VW flat-4 air cooled 215 (245) with heater boxes; 180 stripped
VW flat-4 Type IV 311 (109)
VW flat-4 Type 4 230 (189) Complete, uprighted, less exhaust system
VW flat-4 Type 1 250 (163) 1600cc dual port, stock flywheel,
clutch, doghouse oil cooler, Monza
muffler, Bosch alternator, twin
Solex/Kadron carbs with manifolds and
linkage, heater boxes, all sheet metal,
without oil
VW 1.5L L4 Diesel 246 (226) w/ oil, int/exh man, no alt. or starter
VW Rabbit 1.6-1.7-1.8 231 (245) Dasher, Scirocco, Jetta, Omni, Horizon
Vauxhall Calibra 245 (75) 24v, 2.5L V6
Vauxhall Swindon 230 (106) race motor, 2.0L
Vauxhall 16 valve 237 (199)
Vertemati 62 (169) SOHC 4 stroke single, 503cc, 56HP
Volvo B20E 340 (104)
Volvo B21F&B23F 365 (104)
Volvo 3.0 L6 DOHC 401 (56) all aluminum
Wright Flyer flat-4 170 (126) original 1903 Kitty Hawk engine 14hp
Wright L4 aero 170 (254) 1906-1912 model, 240 CID
Wright R3350 Cyclone 3029 (87) aircraft radial
Wright R2600 Cyclone 1950 (257) aircraft radial, 2x7 rows, 2603 CID
Wright "T" aero 1180 (251) 600hp aero, early '20s
Wright "J" aero 470 (251) 200hp, 9 cyl radial, early '20s
Wright "P1" aero 800 (251) 400hp radial, early '20s
Yamaha OX66 75 deg V6 230 (44) 16.5" long, 21.5" wide
Yamaha OX88 75 deg V8 320 (40,52) Formula 1, 3.5L, 22.0L x 22.4W
Yamaha OX99 70 deg V12 308 (70) F1
Yamaha TZ500 sq.4 120 (206) two stroke, race bike, 1980-1981
Yamaha FJ600 135 (101) MC, without intake or exhaust
Yamaha YZ400F 59 (169) DOHC 4 stk. single, 5 valve, 426cc, 57HP
Yamaha XS650 twin 170 (172) 1981 model, with oil
Yamaha '85 RZ350 78 (192)
Yamaha '86 FZ750 155 (192)
Yamaha '90 FZR400 112 (192)
Yamaha YPVS 350 77 (192)
Yamaha V-Max 260 (198) complete but for radiator
Yamaha TT600, '86 95 (217)
Sizes: These figures can be *very* misleading! Shape is usually more
important than maximum dimensions.
ref Length Width Height
Alfa 155 V6 TI (75) 500mm
Allison V12 (160) 44* 30 36 *62 w/acc drives
BRM "290" V12 (74) 650mm
BRM V12 1965? F1 (87) 29
Buick 3.8 V6 (60) 22.0 24.0 24.2
Buick 3.8 V6, RWD Regal (dw) 24.5 V-belt accessories
Buick V6 (odd fire) (245) 25.25
Buick 215 V8 (245) 28.5
Chevy LT1 (1994) V8 (60) 27.2 24.8 23.0
Chevy Sprint 993cc L4 (55) 24 20 25 Suzuki engine
Chevy 193-292 L6 (dw) 33
Chevy Vega 2300 4 (245) 23.25
Chevy II 4 (245) 24.25
Chevy small block V8 (234) 28 25 22
Chevy 327 V8 (245) 29
Chevy Citation V6 2.8 (245) 19.75
Cosworth V8, 1965? (87) 21.5
Cosworth 75 deg V8 (52) 23.4 23.3 20.5
Cosworth HB 75 deg V8 (52,63) 23.4 23.3 20.5
Cosworth HB Series 6 (70) 595mm
Cosworth MBA V6 (67) 26.25 20.5 27.75
Cosworth XB V8 (89) 22.2 21.7 21.9
Cosworth ED 75 deg V8 (103) 23.4 21.3(*) (*) inc Air filter
Cosworth V8, 1967 (136) 21.4 27.0
Cosworth CR-1 V10 (144) 569mm 509mm 375mm
Cosworth 2.5 V6 (196) 24 19 21 prototype, not prod.
Drake Indy V8 (1978) (138) 25 25 22
Dodge Colt 4 ('70s) (245) 21
Ford-Cosworth DOHC V8 (60) 22.2 21.7 21.9
Ford-Cosworth DOHC V8 (240) 22.2 21.7 21.9 circa 1995
Ford Mod V6 2.5L 60deg (81) 22 24 24
Ford CDW27 460mm
Ford Kent OHV (234) 21 22 24
Ford Kent 1600 (245) 21
Ford Pinto 2000 (234) 23 24 27
Ford Pinto 2000 (245) 22.5
Ford Pinto 2300 (245) 24.5
Ford Essex V6 (234) 25 24 26.5
Ford Essex V6 (238) 25.5 27.2 26.8 w/o air cleaner, with alt
Ford Cologne V6 (234) 25 24 26.5
Ford Capri V6 (Cologne) (245) 23 21.5
Ford Windsor V8 260 CID (234) 28 21 22
HS Performance 2.0 V8 (63) 488mm 552mm 478mm
Hart V10 F1, 72 deg V (63) 622mm 560mm 535mm
Honda 3.5L 72 deg V10 (40,52) 24.4 21.7 21.3
Honda 3.0 VTEC V6 (129) 486mm 627mm 647mm "fully dressed"
Honda Civic 1200, 1974 (151) 26.8 18.4 24.6
Honda Civic 1500, 1974 (151) 21.4 20.2 25.5
Honda CVCC 1500, 1974 (151) 21.7 20.4 26.6
Honda Civic (245) 18.63
Ilmor 2175A 72deg V10 (59) 592.5mm 519mm 555mm
Ilmor DOHC V8/C (60) 22.0 22.0 22.8
Ilmor V-8-C (75) 22.1 22 22.8
Ilmor 265B V8 (210) 595mm
Ilmor 265C V8 (210) 560mm
Ilmor 265D V8 (210) 555mm
Judd GV 72 deg V10 (70) 630mm
Lamborghini F1 80degV12 (70) 719mm
Lycoming 36 cyl radial (87) +10 feet
Lycoming 36 cyl radial (178) 10 feet 5 feet 5 feet
Mazda 2.5V6 452mm
Mazda 13B FI (197) 515mm 535mm 640mm
Mazda RX2,3, and 7 (245) 19 16
Mazda RX4 (245) 20
Mercedes-Ilmor OHV V8 (60) 22.1 20.1 25.7
Mercedes-Ilmor DOHC V8 (89) 22.05 21.85 22.44
Mercedes F0110 75dg V10 (103) 590mm 485mm 472mm
Mercedes IC108C V8 (130) 560mm 550mm 570mm
Mercedes F1 V10, 1994 (210) 592mm 496mm 545mm
Mugen V10 72 deg (70) 620mm
Mundy Trident W-12 (85) 20.5
Nissan VRT35 GTP V12 (66) 660mm 577mm 533mm
Renault G-ser. 2.2 12v (107) 515mm 598mm (1996)
Renault V10 (52) 26.3 21.7 17.3
Renault RS3B V10 (70) 620mm
Rover 3500 V8 (234) 32.5 26 29.5
SAAB V4 (245) 15.5
Subaru flat-12 F1 (52) 29.3 28.5 15.7
Subaru flat-4 (245) 16.25 15.5
Suzuki H20A V6 (92) 650mm 620mm 815mm 60deg V6, 2L
Toyota 2TC (245) 23.5
Yamaha OX66 75 deg V6 (44) 16.5 21.5
Yamaha OX88 75 deg V8 (40,52) 22.0 22.4
Yamaha OX99 70 deg V12 (70) 725mm
VW 1.5-1.9L L4 (Rabbit) (226) 19 15 26
VW Beetle flat-4 (245) 14.25
Transmissions
maker weight gears type source comment
Alfa Romeo 195 manual (166) '76 Alfetta GT transaxle
Borg Warner 101 4 speed manual Ford Super T-10 iron/aluminum
Borg Warner 92 4 speed manual Chevy Super T-10 iron/aluminum
Borg Warner 130 4 speed manual (158) 1927 model T-4, for 1927 Paige 8 (dry)
rated to 175 ft-lb
Borg Warner 78 5 speed manual (85) T-5, Ford pattern
Borg Warner 65 5 speed manual (243) T-50, GM pattern
Borg Warner 140 6 speed manual (253) T56 (Dodge Viper)
Clark 450 238 5 speed manual (253) 490 ft-lb rating
Ford 48 4 speed manual (85) '71 Capri/Pinto 1600 light duty
(iron case, aluminum tailshaft housing)
iron bhsg 23#
Ford 103 4 speed manual (232) Top Loader
Ford C6 ~202 3 speed auto (152) Big block C-6, 165 lbs, Transmission
weight, drained, without torque
converter 37 lb, Torque converter
weight, mostly drained
Ford C6 ~171 3 speed auto (154) no fluid
Ford C4 ~185 3 speed auto (152) Small block C-6, 150 lbs, Transmission
converter 35 lb, Torque converter
Ford AOD 184 4 speed auto (154) (without fluid)
Ford AOD 195 4 speed auto (159) including torque convertor
Ford FMX ~195 3 speed auto (154) cast iron case
Ford FMX 195 3 speed auto (159) iron case
Ford 228 3 speed auto (154) Ford-O-Matic (pre-FMX), cast iron
case (early '60s)
GM Hydramatic ~250 4 speed auto (195) w/fluid clutch
GM TH200-4R 117 4 speed auto (85) dry, no convertor
Jerico 72 4 speed manual (145) mag. case with integral coolant pump
Jerico 68 4 speed manual (145) mag. case w/o integral coolant pump
Jerico 52 2 speed manual (149)
Mitsubishi 110 5 speed manual (146) '91 VR4 transaxle, less transfer
Mopar A-833 116 4 speed manual (232) heavy duty
New Venture 200 5 speed manual (252) NV3500, HM290, 5LM60 integral bell
New Venture 200 5 speed manual (252) NV4500 iron case
New Venture 200 5 speed manual (253) NV4500
New Venture 360 6 speed manual (252) NV5600 iron case, aluminum bell
Porsche 89 5 speed manual (147) 901 transaxle
Porsche 109 5 speed manual (147) 915 transaxle
Richmond 140 6 speed manual (232)
Saginaw 149 4 speed manual (147) Corvair IRS transaxle
Saginaw 82 4 speed manual (85) iron case
Saginaw ~150 4 speed manual (245) Corvair transaxle
Studebaker 46 3 speed manual (187) Champion 1948 to 1954
Toyota 77 5 speed manual (243) W55, 57, 58, 59 Celica Supra, 9 bolts
and two dowels to bellhousing
Toyota 99 5 speed manual (243) Crown, Corona, Celica, Cressida, iron
case, 7-bolt bellhousing flange
VW 71 4 speed manual (147) Beetle IRS transaxle
VW 79 4 speed manual (147) Bus IRS transaxle
ZF 135 5 speed manual (147) Pantera transaxle
ZF 145 6 speed manual (232) 1989+ C4 Corvette
ZF 196 6 speed auto (262) BMW 7-series, 2002-up
ZF 220 5 speed auto (262) BMW 7-series, before 2002
Sources:
unattributed data: from my paper notes of yesteryear
otherwise:
(1) Handbook of Engine Swapping, John Thawley, 1960
(2) Complete Handbook of Automotive Power Trains, Jan Norbye, 1981
(3) Passenger Car Engines, papers, IMechE, 1975
(4) New Light Duty Engines, SAE 510, 1982
(5) Hot Rod Engines, Hot Rod, 1967
(6) Aspects of Internal Combustion Engine Design, SAE 582, 1982
(7) Popular Science, May 1984
(8) Automotive Industries, June 1993
(9) Cycle Magazine, Cook Neilson, "TDC" Feb 1990
(10) Street Rodder, Neal Muyleart, "Aluminum Manifold", Aug 1993
(11) Popular Science, March 1974
(12) Popular Science, September 1982
(13) Popular Science, May 1972
(14) Popular Science, April 1974
(15) Popular Science, December 1977
(16) Popular Science, November 1973
(17) Automotive Industries, July 1992
(18) Ford SVO V-6 Racing Engine Builder's Guide, 1992
(19) "Streamlining and Car Aerodynamics", Norbye, 1977
(20) "The New Mazda RX7 and Mazda Rotary Engine Sports Cars",
Jack Yamaguchi, 1985
(21) Popular Science, April 1979
(22) Autotech, April 1988
(23) Racecar Engineering, V2 N6 1993
(24) Sports Car International, October 1992
(25) Road & Track, February 1994
(26) Collectible Automobile, January 1986
(27) Road & Track, December 1970
(28) Road & Track, August 1980
(29) Road & Track, February 1992
(30) Car and Driver, March 1992
(31) Superauto Illustrated, October 1986
(32) Sports Car International, January 1993
(33) Sports Car International, June 1992
(34) Automobile, November 1991
(35) Motor Trend, September 1993
(36) Road & Track, April 1980
(37) Road & Track, August 1993
(38) Car and Driver, January 1984
(39) Popular Mechanics, June 1981
(40) Road & Track, January 1989
(41) Road & Track, December 1993
(42) Motor Trend, August 1990
(43) Sports Car International, July 1990
(44) Road & Track, May 1985
(45) Automotive Industries, May 1994
(46) Machine Design, May 23 1994
(47) Automotive Industries, April 1994
(48) Hot Rod Ford High Performance 1985
(49) Road & Track, May 1989
(50) Road & Track October 1979
(51) Motor Trend, September 1972
(52) Road & Track, June 1989
(53) Road & Track, September 1984
(54) Motor Trend, June 1985
(55) Motor Trend, August 1984
(56) Motor Trend, August 1987
(57) Road & Track, July 1987
(58) Car Craft, July 1994
(59) Racecar Engineering, Summer 1991
(60) Circle Track, August 1994
(61) Car Design & Technology, July 1992 (British)
(62) The World's Fastest Cars, Publications International Ltd 1989
(63) Racecar Engineering, Vol 2 Number 5
(64) Racecar Engineering, Vol 3 Number 1
(65) Car Design & Technology, November 1992 (British)
(66) Racecar Engineering Vol 2 Number 2
(67) Car Design & Technology, March 1992 (British)
(68) Car Design & Technology, June/July 1991 (British)
(69) Car Design & Technology, September 1992 (British)
(70) Car Design & Technology, June 1992 (British)
(71) Car Design & Technology, May 1992 (British)
(72) Motor Trend, September 1993
(73) Car Design & Technology, October 1992 (British)
(74) Racecar Engineering, Vol 2 Number 3
(75) Racecar Engineering, Vol 3 Number 3
(76) Racecar Engineering, Vol 2 Number 4
(77) Automotive Industries, November 1992
(78) Sports Car, March 1994
(79) Automotive Industries, July 1992
(80) Automotive Industries, December 1992
(81) Automotive Industries, October 1993
(82) Automotive Industries, February 1994
(83) Super Cars, December 1978
(84) Racer, September 1994
(85) dave.williams@chaos.lrk.ar.us, on scales
(86) Automobile Design: Great Designers and Their Work (1970)
(87) Some Unusual Engines, LJK Setright, 1975
(88) Corvette Quarterly, Spring 1995
(89) Machine Design, May 11 1995
(90) Automotive Engineering, July 1995
(91) Machine Design, June 15, 1995
(92) Automotive Engineering, April 1995
(93) Car Craft, October 1990 (via thaxton@kscdm6.cad.ksc.nasa.gov)
(94) Design News, October 5 1992 (via thaxton@kscdm6.cad.ksc.nasa.gov)
(95) Haynes International Race Engine directory, via: Eric Verschuur
(96) The Wankel Engine by Jan P. Norbye (Chilton, '73, ISBN 0-8019-5591-2)
via: Eric Verschuur
(97) Automotive Quarterly, vol 22, no 1 via: Jim Davies
(98) Jim Davies
(99) 1955 Chrysler Service Manual - Imperial, Windsor, New Yorker, 300
(100) dale@wyvern.wyvern.com (Dale Maurice)
(101) David Alan Clemens
(102) LLOYD ROBERT C
(103) Dan Jones
(104) Haynes manuals, via: jcatford@rsvs.ulaval.ca (Jean-Guy Catford)
(105) jcatford@rsvs.ulaval.ca (Jean-Guy Catford)
(106) Cars & Car Conversions, February '95, via: amm@tremas.dct.ac.uk
(Angus Marshall) (British)
(107) Automotive Engineering, November 1995
(108) Automotive Industries, January 1995
(109) Kit Car, March 1995
(110) Automotive Industries, February 1995
(111) Exotic Cars Quarterly, Summer 1991
(112) Hot Rod Engines 1992
(113) Kitplanes, April 1994
(114) Kitplanes, September 1995
(115) Hot Rod, April 1996
(116) Machine Design, May 9, 1996
(117) Automotive Industries, March 1996
(118) Automotive Industries, June 1996
(119) SAE 890877, "Honda Formula One Turbo-Charged V6 1.5L Engine"
(120) SAE 640252, "The Ford D.O.H.C. Competition Engine"
(121) SAE 660742, "The Coventry Climax Racing Engine 1960-1965"
(122) Popular Hot Rodding, October 1988
(123) Automotive Engineering, May 1996
(124) Peterson's Complete Book of Ford, 3rd Edition, 1973
(125) Surplus Center, 1997 catalog
(126) Kent's Mechanical Engineer's Handbook, 12th Ed. 1950
note: many utility Diesel and aircraft engines listed in this book
(127) Automotive Industries, March 1997
(128) Automotive Industries, October 1996
(129) Automotive Industries, September 1996
(130) Automotive Engineering, December 1996
(131) Automotive Engineering, January 1996
(132) Automotive Engineering, June 1997
(133) Automotive Industries, October 1996
(134) Fast Car, August 1996 (British)
(135) Motor Trend, August 1967
(136) Road & Track, July 1967
(137) Road & Track, August 1967
(138) Hot Rod, May 1978
(139) Vari-Prop ad, Sport Aviation February 1995
(140) Automotive Engineering, December 1982
(141) Machine Design, April 3 1997
(142) Design And Development Of The Indy Car, Roger Huntingdon
(143) Ward's Auto Reports Online September 1999
(144) RaceTech Magazine web site January 2000
(145) Jerico 1994 catalog
(146) Jay Klahr, February 1997
(147) Kit Car March 1995
(148) "Jaguar: Performance and Pride" by Pete Lyons and the Auto Editors of
Consumer Guide, published 1991, via "VanOeveren, Ron"
March 1996
(149) Jerico ad, Circle Track August 1996
(150) Jack Chesley 14 March 1996
(151) Road & Track April 1974 via Craig Blome
September 1996
(152) "S. Grossen" January 1997
(153) "Sparkman, Jeffrey" 13 February 1997
(154) "Dan. Jones" January 1997
(155) Machine Design, June 11 1992
(156) The Complete Official 948cc and 1098cc Sprite/Midget: 1961-1966
Robert Bentley ISBN 0-8376-0023-5 via Craig Blome
October 1999
(157) Frederic Breitwieser 24 September 1999
(158) Automotive Industries July 1996
(159) Popular Science, August 1979
(160) jfross@ix.netcom.com (John Ross), rec.crafts.metalworking,
17 November 1996
(161) Ed Raden June 1997
(162) Brian Knowles 29 August 1997 (his scale)
(163) "Leavitt, David R" September 1999
(his scale)
(164) Stephen Wilson 22 September 1997 (his scale)
(165) Joel Koenigs 23 May 1997
(166) Brian Knowles November 1997
(167) Will Klopfenstein May 1997
(168) Car Craft March 1998
(169) Hugo van Waaijen 11 Aug 1999
(170) Brian Knowles 25 Jun 1997 (his scales)
(171) Dvbai@aol.com 21 Aug 1997 (his scale)
(172) RWa11@aol.com 30 Jun 1998 (his scale)
(173) Hopkinsmik@aol.com 01 Oct 1998
(174) http://www.aviation-history.com/engines/allison.htm
(175) http://www.aviation-history.com/engines/clerget.htm
(176) http://www.aviation-history.com/engines/db605.htm
(177) http://www.aviation-history.com/engines/super.htm
(178) http://www.aviation-history.com/engines/xr-7755.html
(179) http://www.aviation-history.com/engines/pr-1937.htm
(180) http://www.aviation-history.com/engines/pr-2800.htm
(181) http://www.aviation-history.com/engines/wr-1937.htm
(182) http://www.gmpowertrain.com/ind57PS.htm
(183) http://www.gmpowertrain.com/ind65PS.htm
(184) http://www.gmpowertrain.com/ind74PS.htm
(185) Contact! issue 41, via Brian Knowles 12 Feb 2000
(186) John Robinson 101546,3555 CIS S17/European & UK Cars #728212 13-Feb-97
(187) Dcat917@aol.com 09 Feb 2000
(188) Tom Hill 26 Dec 1999 on his scale
(189) Joe Locicero 28 Mar 1998
(190) http://www.audi.co.za/environment/weight/weight.html via
"Craig A. Blome" 13 Dec 1997
(191) Automotive Industries November 27, 1937 via
Marvin McConoughey 29 Apr 1997
(192) Jerry Wills 01 Dec 1998
(193) Chuck Karish karish@mindcraft.com
(194) Scott McClelland scottm@hprpcd.rose.hp
(195) Bob Hale x594 7 Oct 98
(196) Automobile July 1991
(197) steveb@indy.net (steve benson) rec.autos.tech 9 Sep 1995
(198) Ian Drysdale 20 Jun 1999
(199) Daniel1312@aol.com 31 Dec 1999 (unknown magazine article)
(200) "Steve N." 18 Feb 1999
(201) Laszlo Szerenyi 4 May 1999
(202) http://www.eagle.ca/~harry/aircraft/tempest/sabre/
(203) http://www.csd.uwo.ca/~pettypi/elevon/b … rn-01.html
(204) Cycle World, December 1985
(205) Cycle World, February 1985
(206) Cycle, September 1984
(207) Modern MOTOR, June 1984 (Australian)
(208) Motorcyclist, April 1987
(209) Cycle World, November 1986
(210) Racecar Engineering, Volume 3 Number 5, 1994
(211) Honda CB650 factory service manual, 1980
(212) Cycle World, July 1987
(213) Cycle World, April 1984
(214) Ian Drysdale mc-chassis-design@list.sirius.com
04 Dec 1998
(215) Michael Moore mc-chassis-design@list.sirius.com
03 Dec 1998
(216) Michael Moore mc-chassis-design@list.sirius.com
03 Dec 1998
(217) Jim Schneider mc-chassis-design@list.sirius.com
04 Dec 1998
(218) Motorcyclist, May 1978
(219) Motorcyclist, October 1985
(220) Motorcyclist, April 1978
(221) Automotive Engineering, May 1997
(222) Cycle World, June 1969
(223) David Meek , 10 Dec 1999
(224) Anton Krivanek 10 Jun 2000
(225) "Fraser, Adam" 07 Jun 2000
(226) GLGREEN232@aol.com 15 Feb 1998
(227) Michael Smart 03 Nov 1999
(228) GD 18 Apr 2000
(229) James Gibat-Thoroski, http://members.fortunecity.com/mercurycapri/
projectrsx/v8sho/shonotes.html 11/00
(230) ScottyCBoy@aol.com 22 Apr 1999
(231) Robert 13 Apr 1998 referencing
http://web2.airmail.net/robmu/eyewtk.html
(232) John Slater 27 Jun 1998
(233) Automotive Industries, February 1996
(234) Fast Car, February 1992 (British)
(235) Chevy High Performance, July 1998
(236) CAR, November 1986
(237) Motor, March 19 1983 (British)
(238) Capri Mild to Wild, October 1984 (British)
(239) Circle Track, July 1998
(240) Machine Design, May 11, 1995
(241) David Hardcastle, "The Rover V8 Engine"
(242) "Hot Rodding The Compacts". Peterson, 1964
(243) MG V8 Newsletter v4n1
(244) Solar Automotive conversion brochure
(245) Kennedy Engineered Products adapter catalog
(246) Peterson's Complete Book of Engines 1965
(247) Car Craft, February 2000
(248) http://home.t-online.de/home/gerhard.ki … engine.htm
(249) http://www.exeter-falcons.demon.co.uk/techspec.htm
(250) NACA TN-34, 1921
(251) NACA TN-211, 1925
(252) ATSG web page, 2001
(253) 21St Century Turbo
(254) http://www.ohtm.org/eng_wright.html
(255) http://www.ohtm.org/eng_gnome.html
(256) http://www.ohtm.org/eng_clerget.html
(257) http://www.ohtm.org/eng_cyclone.html
(258) http://www.ohtm.org/eng_liberty.html
(259) http://www.ohtm.org/eng_wasp.html
(260) http://www.ohtm.org/eng_hallscott.html
(261) Cycle World, May 1979
(262) Automotive Engineering, March 2002
(263) Machine Design, Jul7 8, 2004
