Re: Brake pads
We're running with el cheapo "China Will Go Stronger" rotors, and EBC Yellowstuff pads on out E30. We've now run the equivalent of one whole race, and the pads aren't even half worn. We've removed the dust shields from the front brakes, but not from the rears, and have determined via inspection that the rears are running a decent amount hotter than the fronts, so we're going to pull/cut off the rear shields for 2010.
Our primary problem right now is that the brakes constantly feel a bit too spongy four our liking, despite the smaller-than-stock booster. We've bled the brakes about 10 times between buying the car and now, and have never gotten any air out of the system when we've tried to re-bleed after thinking "these are soft--must be air in the lines". We'll also likely go to SS flex lines for 2010 as well, so hopefully that will help a bit.
