russian wrote:derekste wrote:Post race dissection indicated to the contrary- the MAF and wastegate solenoid wires (9 in total) were more or less shorted to one another (and possibly the headlights as well). Despite this, the car ran OK-ish for the race
That would be more or less the wost possible nightmare possible.
you'd think so, but the fail state for the N75 (what VAG calls the WG solenoid) is bypass, and no MAF = open loop operation, assuming the MAP is working (I should check that).
it gets worse:
for its debut (RoadAmerica 2013) and first race this season (GMan), I had the auxiliary waterpump harness connector plugged into the IAT sensor- so I was (a) sending 12V to ECM ground and (b) not having the benefit of IAT measurement. (remember PV=nRT? I was missing V & T...)
fun doesn't stop there:
between GMan and Autobahn, I also discovered the blowoff valve had a torn diaphragm. this in and of itself isn't so bad- until you realize the vac reference line used by the BOV is shared with MAP, FPR, and your diff locks. Cross "P" off the list, too.
tl;dr
how has this thing not blown up yet?
"THE WONDERMENT CONSORTIUM"
