bigds01 wrote:I was way, way outside the box. Problem is that you have to move to discs from the drums and there were real clearance problems. The master cylinder on the 70's rolls were driven off the engine so replacement is very hard. Most people use a truck master cylinder but stick with the drums and mineral oil.
I was going further out of the box than just changing the master cylinder or even just the brakes. Why not do as folks have done with things like the Wartburg/Subaru or the recent Alfa/MR2? Put the Rolls body on a more modern SUV frame. This solves your driveline problems, suspension problems (well, at least gives you something you can work with), and brake problems in one king-sized swoop.
The work would be plenty, but the cost would not be $12,000.
